#21
Re: consensus on 10?
Count me among those who haven't had a single hiccup, glitch, or gack. I've found 10 to be quite steady and solid, as was 9 before it.
[Disclaimer: The vast majority of what I do is record live classical music, with very little heavy-duty editing involved. I don't have to worry about monitor mixes or overdubs, or any elaborate signal routing, or any of the other things that most of the DUC denizens deal with on a daily basis. That said, I've still found PT to be more stable than REAPER, in that I can consistently crash REAPER by loading AU versions rather than VST versions of certain FX or VI's. All of my plugins are Avid-compliant, and they've all worked from the get-go.] Cheers, GT
Mac Pro 6,1 ("Garbage can"), late 2013, 3 GHz 8-Core Intel Xeon E5; 64GB RAM; MH ULN-2 (Ethernet MHLink connection) PT Ultimate 20.12.0; REAPER64; PreSonus Studio One 5 Pro, Central Station Plus, and FaderPort McDSP All Access; Slate Digital All Access; Waves Diamond 12.0; NI Komplete; EW GhostWriter Finale 26.3.1 |
#22
All goodz here.. Love it.. I like it better than 9 for certain..
Sent from EPIC 4G using Tapatalk On'eim...
#23
Still no fix?
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
#24
No issues whatsoever with mine. Using the updated 10 and love it. I have been fortunate in that the issues I have had we're my own doing and did help my learning curve.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
#25
Bassilik: You've been here long enough to know that Avid is not the fastest when it comes to bug fixes or updates. I'd give it 6 months or more. Maybe PT11 will even come out before this fix. I haven't seen the bug so I'm still good with PT10. PT9 and PT10 has been the best versions for me and I've been using PT since PT5.x.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
#26
I've had times when I was getting the audio dropping out bug a lot and other times when I haven't seen it for weeks.
I currently am in the stage where I haven't seen the bug for a long time (knock on wood) and I am so happy with Pro Tools 10. I really wish it was 64 bit all the way through, but definitely my favorite Pro Tools yet. Disk Caching is the best. Other features and enhancements are great! Besides the audio dropping out bug, I would say that PT 10 is ready for prime time. PT will never be bug free, but it is quite stable right now. When you run into the audio dropping out bug, disable all outputs by holding down Cntrl-Option-Command and click on one of the outputs. Then enable the outputs again and you should be back in business for awhile. Much faster than restarting PT and faster than changing interfaces for me.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
#27
Dizzi,
If you see the "Audio Stops playing" stickie above, I've just had it confirmed on my Support thread, that this is fixed (or at least they've found the fix) and it will be rolled into an upcoming release. Good news hopefully. Cheers. Steve Bush www.music180.com/pros/5887 2 x Systems: MacPro 4.1 (Nehalem) 2.26 8 Core, OSX 10.6.8, PT10HD, 14 Gig RAM, PCIe HD3, 192's, Sync I/O, Midi I/O. |
#28
Sadly, full of bugs. I'm running a project exclusively to see how buggy it is, so far it's liveable but it's not very reassuring to come across issues that shouldn't exist in the 1st place.And when you do come across issues trying to figure out how to work around them.
Cory Rizos, CAS Re-recording Mixer/Sound Designer Montreal, Quebec http://www.imdb.com/name/nm0007185/ coryrizos.com |
#29
Ableton Live is my main daw, so buying PT 10 would be a downgrade..
Just Run Pro Tools as a Rewire Slave/Run Parallel.. its easier than you think. Example- RME TotalMix and the IAC Midi Driver http://duc.avid.com/showthread.php?t=313749 |
#30
Workin' well over here...
Sparky |
PT 10 & DIGI002 - What's the consensus? | Darney | macOS | 7 | 11-05-2011 07:29 PM |
General consensus PT9 | basslik | Pro Tools 9 | 44 | 03-09-2011 03:55 PM |
PT 8 on XP, where is it at, consensus? | dubrichie | Pro Tools TDM Systems (Win) | 12 | 03-15-2010 08:54 PM |
10.4.11 consensus | Phil Jeffers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-26-2007 01:36 PM |
What's the consensus: keep 6.0.1, or load 6.1? | soundboy69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 07-24-2003 06:36 AM |
