Old 05-28-2010, 08:11 PM
skyking skyking is offline
Default Help Needed on Hardware Issue
i had an issue with Windows xp pro and had to have get windows reauthorized and when i did and rebooted i got the "new hardware found" msg...the new hardware being found is my 002 and of course now my pro tools dont boot up...its been yrs since i installed my 6.9 pro tools and honestly i forgot but seems to me there was some authorization required there too and i know digidesign has changed too...so can someone tell me what i need to do to reinstall my 6.9 version i was running....i know i have to run the disk of course but isnt there some authorization procedure required there too??.i looked in my emails to see if i had anything from digi regarding passwords or authorization codes...nuttin!!......any help appreciatted
Digi 002 on windows xp pro .. pentium 4 @ 1.6 ghz....intel 845 chip...gigabyte p4 titan MB....seagate hd.....40 and 120 gb @7200....1 gig of ram
Old 05-28-2010, 10:00 PM
Shan's Avatar
Shan Shan is offline
Default Re: Help Needed on Hardware Issue
What occurs at this point exactly when it doesn't boot up? Is there an error message or dialog?
6.9 was a good release by the way with a very snappy and responsive U.I.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 05-28-2010, 10:05 PM
stonehenge stonehenge is offline
i think you'll need the 6.7 code described here - http://avid.custkb.com/avid/app/self...p?DocId=351651
Old 05-29-2010, 10:25 AM
Thanks for getting back to me....what happens when i try to boot up my pro tools is after all my plug ins load i get the little window that says "unable to locate hardware...make sure hardware is connected and click ok when hardeware is ready.....when i click ok that little window just blinks and stays on my screen..
also when i go in "device manager" there is a yellow flag next to my 002 and it says the driver needs to be installed...hope that info helps
Old 05-29-2010, 11:55 AM
TCM's Avatar
TCM TCM is offline
power harness issue?
firewire problem?
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 05-30-2010, 05:19 PM
Shan's Avatar
This indicates your driver wasn't installed properly. What version of XP Pro are you using? SP1, 2, or 3?
Shane
Old 05-31-2010, 08:19 PM
Shan sorry it took so long to respond i was out of town ....I am using xp pro with sp3
Old 06-01-2010, 12:34 AM
Shan's Avatar
Since the hardware driver didn't seem to install, I would reinstall Pro Tools then check Device Manager to make sure it's there.
Shane
Old 06-01-2010, 08:57 AM
I would try to test the 002 on another system as they are notorious for the power harness issue as mentioned. Then I would pop in the Pro Tools disk and then go to Control Panel>System>Hardware>Device Manager and find the 002 with the yellow exclamation mark, then right-click and choose Update Driver. Choose "install automatically" and see if it finds the driver from the disk. Or right-click and uninstall it, then reinstall. Spending all this time, will suck if you come to find out that the power harness is the problem all along.
Old 06-01-2010, 10:35 AM
IT WORKS!!!!!!!!!!.......First of all thanks to all that tried to help me on this...much appreciatted!!....I ran the disk and windows automaticly installed the driver and Waaa laaaa it worked and seems to work fine.....Albee i have had my power harness out and cleaned the terminals a few times and i think i need the improved power harness..it has been a problem....i thought you mentioned sometime back you had extras...do you still have one i could buy or can someone let me know where i can get one??............again Thanks!!!
Hardware needed for Protools 10? legspin Windows 2 05-14-2012 01:12 PM
Help needed with EZDrummer issue boycie Virtual Instruments 4 04-11-2012 04:37 PM
002LE Hardware Issue. Hardware sometimes restarts/powers off Neruk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-06-2007 03:38 PM
Raid issue - help needed please :-) Chroizz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-27-2006 03:03 AM
Hardware Needed? Tony Moore Pro Tools M-Powered (Win) 1 10-12-2005 07:10 AM
