#41
Re: Pro Tools 11 Beginner
If the Scarlett is showing as a playback engine option, but not showing up as an option in the track I/O dropdown menu; Go to Setup>I/O Setup>click Default buton. BTW, You won't get good performance without a separate 7200 drive to record sessions to. The Western Digital Caviar 'Black' are proven to work well. The higher the cache the better. A dedicated video card (as opposed to integrated graphics) is strongly advised. Also, you have mis-matched RAM. Best to have matching sticks.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
#42
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#43
OK. I got things running and can record and playback with the Scarlett. Latency is a problem when recording, and I assume that this is because of the 5400 drive. Next question: Can I stick with the 5400 in the laptop for now and just add the 7200 external drive to "smoothe" things out until I can upgrade the guts in my laptop? Believe it or not, I actually have a Black Caviar 7200 sitting around that someone gave me last summer! Talk about good fortune. Anyway, it is obviously meant to be inserted into a desktop CPU. Is there some kind of case I can put it in soviet is my external drive? If so, how would I connect it to my laptop for use? Through one of my USB ports? Thanks again and again to everyone for their input!!
Matthew
System Details |
#44
The short version is that your audio device has to stream in two directions. Each stream fills up buffers, which then are dumped. Think of it like a bucket brigade.. As a result, you get a bit of delay. The good news is that your interface probably has a "zero latency" monitoring mode which will allow you to monitor whatever you feed into it, before it gets sent to the computer (see above link). |
#45
In the Playback engine, change the H/W Buffer Size to as low as it can go. You can also use Low Latency Monitoring:
Pro Tools > Options > Low Latency Monitoring Both those features are explained well in the Pro Tools Reference Guide. Your Focusrite Scarlett also has direct monitor control on the front panel which lets you monitor without any latency. There are many various external enclosures you can use for your separate audio drive. Apparently your laptop also offers a SATA III interface for full support of 6 Gb/s drives, which you can look at down the road. Shane
#46
Thanks again, Shane! Any advice on how to put my Caviar drive into some sort of shell or case and how to hook it up to my laptop?
System Details |
#47
This is the hard drive that I have available to use: http://www.amazon.com/gp/product/B00348Q8JW
Is this cable, and some sort of case, all that I need: http://www.amazon.com/C2G-Cables-305...ref=pd_cp_pc_0
System Details |
#48
And this for an enclosure? http://www.amazon.com/Vantec-NexStar...ve+adapter+kit
System Details |
#49
System Details |
#50
System Details |
Beginner questions about Pro Tools 11 | SWBoatman25 | Getting Started | 2 | 03-19-2014 10:44 AM |
Pro Tools 11 Beginner | btwnthbttns | Getting Started | 64 | 12-24-2013 04:11 PM |
Beginner Having Beginner Problems Recording | boymales | Pro Tools TDM Systems (Mac) | 4 | 10-01-2007 05:18 AM |
beginner pro tools problems | 907protools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-25-2007 05:27 PM |
beginner on pro tools some help please | Extraaatone | Pro Tools M-Powered (Win) | 2 | 02-07-2007 09:17 AM |
