Old 03-14-2010, 01:09 PM
necjamc necjamc is offline
Default Re: Pro Tools to Reaper... Need some help!
After reading the standalone drivers page, Make sure nothing else is using the 002r when you are selecting it in reaper, if any program is open using it, or any sound is being sent to it it will not work. (The ASIO driver only supports one application using it at a time)
Old 03-14-2010, 01:19 PM
TOM@METRO's Avatar
Originally Posted by DeyBwah View Post
What are the advantages Tom?? I thought Reaper had a way lighter footprint, cleaner code, which in turn makes it an ultra fast DAW, but wouldn't those advantages be lost if I were to ReWire it into PT? And also all the issues with PT would then be present as well right? Or do you mean, just ReWire it in and don't use PT at all, just use Reaper inside of PT?
I'm a little green when it comes to ReWire.. have only had limited experience with it using Reason into PT.
Thanks whorbos!
The advantage is that nothing edits like Pro Tools, I like the best of both worlds.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-14-2010, 01:42 PM
DeyBwah DeyBwah is offline
Originally Posted by necjamc View Post
I read your thread on the reaper forum. Although I can't tell you exactly what's wrong, Those guys don't know anything about Digi Hardware, that I am sure.
You need to find out about the drivers that run non PT stuff. Like iTunes etc, and what drivers you can download for asio things.
Hmm I don't have iTunes installed. Not sure what I could possibly be running that is using ASIO and preventing Reaper from displaying ASIO DigiDesign Driver in the drop down for Audio Device drivers..
On a side note, it's funny how no one knows PT like DUC.
"One should not pursue goals that are easily achieved. One must develop an instinct for what one can just barely achieve through one's greatest efforts."
-Albert Einstein
Windows 7 - Reaper 3 - Lynx Aurora 16 - RME HDSPe AES - DigiMax FS - Eureka - Axiom Pro - Yamaha HS80Ms + HS10W Sub
Old 03-14-2010, 01:44 PM
Originally Posted by Shan View Post
Remove ASIO4ALL.
Here are your ASIO optimizations you need to do. Use the Digidesign ASIO Driver. The entire Digi hardware line has been tested and works using the Digidesign ASIO Driver and REAPER.
Shane
I've removed ASIO4ALL but my main issue is that I can't even begin to use the ASIO optimizations you provided because the Digidesign ASIO Driver is not an option that I can select. Only option for ASIO is a generic "ASIO".. As Necjamc had mentioned, I'm wondering if something is "holding Digidesign ASIO Driver hostage" in another application.
-Albert Einstein
Old 03-14-2010, 01:46 PM
Amen, old habits die hard! I love PT to edit as well. Although I have yet to try Reaper's editing. I would be willing to sacrifice the time to learn Reaper considering all the other advantages it has over PT though. If I could get it to work that is.. !!!
-Albert Einstein
  #16
Old 03-14-2010, 01:49 PM
Just looked at the screen shot again and my mistake.. it looks like you do select the generic "ASIO" then in the following fields you can select Digidesign ASIO driver, but what I meant was, I can't get to the next fields because upon selecting "ASIO" it crashes instantly!
-Albert Einstein
  #17
Old 03-14-2010, 02:04 PM
Shan's Avatar
Shan Shan is offline
That is the driver "type". It's not a "generic" field.
What version of PT are you using?
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
  #18
Old 03-14-2010, 02:05 PM
Shane
I'm on 8.0.1cs3.
-Albert Einstein
  #19
Old 03-14-2010, 02:11 PM
Shan's Avatar
The editing will need to be customized to your work flow. Time will definitely need to be spent, which can be a turn off for some. The PT editing is good, but it's age is showing and it's way behind the times in many areas now. The smallest changes can make it leaps and bounds ahead of everyone again, but that would take listening to their die hard users.
Let me correct the above. That would take listening to their die hard users and then delivering. This is something Cockos does quite well.
Shane
  #20
Old 03-14-2010, 02:12 PM
TOM@METRO's Avatar
I'm on 8.0.1cs3.
Double check your version number... 8.0.1 has only cs1. Are you perhaps on 8.0.0cs3
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Pro Tools and Reaper compatibility nairobijones General Discussion 1 08-23-2010 08:22 AM
Pro Tools 8 theme for Reaper? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-09-2010 07:51 AM
Pro Tools key shortcuts for REAPER RoMi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-26-2010 02:52 PM
I love pro reaper tools Jenk2k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 03-27-2010 06:25 AM
Reaper and Pro Tools 8? jebwick General Discussion 50 09-23-2009 07:20 PM
