Old 01-25-2018, 03:33 PM
cshaw cshaw is offline
Default PT2018.1 - Disable Tab to MIDI note end?
With PT18, tabbing MIDI notes (with tab to transients on), each press of the tab key tabs to the beginning and end of each note. Is there anyway to revert to the old behavior where it only tabbed to the beginning of each note?
The new way makes tabbing through drum triggers very time consuming.
www.chrisshawmix.com
PT 20.3.0
S1 x2
Artist Transport
Avid Control
iPad 7th Gen
HD Native
Hackintosh i9 3.6 GHz Six Core
MTRX Studio
OSX 13.6.4
Old 01-25-2018, 07:12 PM
Default Re: PT18 - Disable Tab to MIDI note end?
left and right arrow keys
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 01-25-2018, 10:36 PM
Sparky1 Sparky1 is offline
With PT18
How long have I been asleep...?
Sparky
Old 01-26-2018, 07:24 AM
john1192 john1192 is offline
does not work here to Disable Tab to MIDI note end!!! what are you talking about ???
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-26-2018, 08:02 AM
Thanks!
PT 20.3.0
S1 x2
Artist Transport
Avid Control
iPad 7th Gen
HD Native
MTRX Studio
OSX 13.6.4
Old 01-26-2018, 08:10 AM
Thanks!
are you getting it to work on your system ??? i cannot so far ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-26-2018, 09:01 AM
The arrow keys are now used as a "select next midi note" Do not use the tab key for midi notes.
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 01-26-2018, 09:08 AM
i hate writing in these forums anymore .. one simple conversation takes all day ..
i understand this, i have Tab to Transient OFF and am NOT using Tab Key ..
i am Saying that MY Left Right Arrow Keys are not doing this function ""select next midi note"" .. and i am asking how is your doing it ???
are you on extended keyboard or laptop ?? trying to figure what I Am Doing Wrong !!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-26-2018, 10:04 AM
Shan's Avatar
Shan Shan is offline
You'll have to be in Notes view(not Clips view) for the Left/Right Arrows to select the MIDI notes. This solution won't necessarily work with some of the common Tab to Transient editing workflows unfortunately, but give it a go and see if it will meet your needs. I myself do a lot of grouped audio/MIDI editing using Tab to Transient, which the Left/Right arrow command won't suffice in those situations, but it may work in your specific use case.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 01-26-2018, 10:48 AM
Originally Posted by Shan View Post
You'll have to be in Notes view(not Clips view) for the Left/Right Arrows to select the MIDI notes. This solution won't necessarily work with some of the common Tab to Transient editing workflows unfortunately, but give it a go and see if it will meet your needs. I myself do a lot of grouped audio/MIDI editing using Tab to Transient, which the Left/Right arrow command won't suffice in those specific situations.
Shane
hi Shane, thank you for the Clarity .. yes, i was testing in Clips View .. will check out notes view ..
i have seen a few folks complain about losing this function with the NEw Tab in Midi seeing both on and off parts of Midi notes and wanted to see if there is a solution for them ...
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Drawn MIDI note length only staccato notes, regardless of note length kingofallwookies Pro Tools 11 2 02-07-2014 07:10 AM
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
EXPORT MIDI from Stryke NOTE FOR NOTE... riggi Virtual Instruments 1 03-10-2008 07:32 PM
Disable MIDI? bigfrog MIDI 0 02-18-2003 07:01 AM
