8.0.3cs1
Anybody tried the patch to see if it fixes the white noise problem??
Re: 8.0.3cs1
It fixes SysEx. Has a bug report for the white noise been submitted?
filosofem |
Re: 8.0.3cs1
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Re: 8.0.3cs1
So I see.
filosofem |
Re: 8.0.3cs1
)*&#%)@Q% and )#&%)Q*& )#*&%#*&.
I know I'll end up copping it for this, but gimmee a break... 8.0.3 was bad enough with the occasional pops and crackles.. But 8.0.3 cs1 has taken it to new heights... I make my backups this morning and go against my better judgement and install the cs1 update. Restart, trash prefs and databases. Start up PT.. Simple project.. about 10 audio files , about 4 or 5 VI's all disables and hidden. STILL getting the noise... OK.. Create a new project and import the session data.. Halfway through: ACCESS VIOLATION OCCURED UNABLE TO READ LOCATION: 0x00002e5c at address 0x04c2b920 in module ProTools.dll Huh? Close PT and try again.. Same result (3 times total) Last two times I close PT I get another error message at closing: ERROR SIGNATURE AppName: ProTools.exe AppVer: 8.0.03.252 ModName: redline preamp.dpm ModVer:1.0.0.1520 Offset: 000cf14f What one earth is going on? Everything works just fine, (except for the noise), until I try to import session data into a new session... In 8.0.1 I do not get the error messages nor the noise.... and I was having noise issues long before I installed the redline preamp plug a few days ago.. Aren't these updates and cs fixes supposed to fix things? As I recall, the fixes were centered around the eleven rack and users were encouraged to install even if they did not use the e-rack.. Rubbish. There's my vent... if you have suggestions I'm open.. I'll put 8.0.3.(#&%^ back in and remove everything from the plugs folder and see what happens, but honestly.. it's time PT (or maybe my computer) just started working properly.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! Last edited by danander11; 01-20-2010 at 01:59 AM. Reason: Toned it down a notch.... I really shouldn't let this stuff get to me.. |
Re: 8.0.3cs1
Why did you install 8.0.3cs1?
filosofem |
Re: 8.0.3cs1
To see if it might help the noise problem in 8.0.3. Also because Digi recommended it...
I have 3 drives set up... XP w/8.0.1, XP w/8.0.3 cs1, and Win7 64 w/8.0.3... It's not stopping me from working. But if Digi is going to recommend that a user upgrade, then the upgrade should make things better, not worse.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Re: 8.0.3cs1
*Even if you do not use an Eleven Rack, this update is recommended for all Pro Tools HD, LE, and M-Powered version 8.0.3 users to provide session compatibility with other users that may have an Eleven Rack. That is, if you are not sending 11R sessions to other users do not update and furthermore right under that statement there reads: Pro Tools LE 8.0.3cs1 is provided as an interim "customer support (CS)" release to address the issues described. While our testing has not shown these changes to introduce other problems, the fixes described have not been fully qualified by Digidesign. filosofem |
Re: 8.0.3cs1
fwiw, I have spent the last hour pulling all non-digi plugs out, then putting them back into the plugins folder and starting/trying PT one at a time to see if anything triggered it.. Everything was peachy until I got to the PLAY plugins.. I put them back, bang, noise was back. I pulled them out, and went through the trashing routine again, but I still have noise. Sometimes it makes noise, sometimes it doesn't. I'll leave Play and all of the IK stuff out and try importing again to see if it still kicks that error. But I really don't know how to duplicate the noise thing.. It's something deeper than plugs I suspect because HD is having similar issues mac or pc. I dunno.. at any rate... Peace!
Re: 8.0.3cs1
Customer Service updates are at users risk. That is, there has been enough customers reporting this SysEx bug that Digi can issue a fix without breaking anything else in the process. If you don't require that fix don't update and then post that the cs update hasn't fixed such and such.
filosofem |
8.0.3cs1 - will not run | IntelDoc | Pro Tools TDM Systems (Win) | 5 | 03-31-2010 09:21 PM |
Who here has LE 8.0.3cs1? I mean really? | Corrupt Clay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 02-09-2010 12:52 AM |
Does BFD 2 PT Le 8.0.3cs1 | skabuddah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-02-2010 04:33 PM |
8.0.3cs1...........who's first??? | MEAT | Pro Tools TDM Systems (Win) | 15 | 01-25-2010 09:20 AM |
8.0.3cs1 | Defekt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 01-22-2010 04:47 AM |
