#51
Re: just updated to vista, now pro tools does not work
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#52
Yeah there is no reason to run in compatibility mode since PT is Vista compatible. Also I get no window that pops up either saying do you want to do this. Are you sure you dont have a Run as Admin option? Maybe go in and check the permissions and make sure.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
#53
and i ran it in xp mode becuase i figured itd fix the problem with the buffer |
#54
#55
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#56
as i stated before, these are basic options, that are not the issue here. these are all things ive tried way back in the begining when trying to get this program to run right, the problem is much deeper than this. |
#57
Shane
#58
#59
http://support.microsoft.com/kb/305780 the only mention microsoft even makes of this, is what user account you are under. there was never a specific option for each program to be run as administrator. this was somthing they cooked up with vista as a part of further virus protection becuase it forces you to have administrator rights to do anything that is potentially dangerous to your computer, especially if a virus is installed that does it automatically.. like editing the registry, renaming partitions, etc. running as admin is nothing more than being logged in on the main account and clicking yes, or being on other users and giving them admin rights from the main account --virtually the same exact thing as xp, just program based instead of account based. as i said in earlier posts, this is turned off on my machine, its not some core element that effects functionality, it merely blocks things from opening for protection. this is under the security window in vista, not some special developement or compatibilty window, and literally has no effect on programs once its turned off (aside from virus protection). its just one less option you have to screw around with to get programs to launch |
#60
Actually this can make a huge difference in XP also. Often you need to install Power Toys and Tweak UI to create the upper level invisible administrator account. This is not the same as just creating a normal administrator account with a password in the traditional way.
M-Audio C600 Updated Drivers - Don't Work. | thisbridgehascables | FireWire & USB Audio Interfaces (Mac) | 6 | 04-23-2014 06:30 AM |
Will LE 6.9.2 work under updated Mac OS? | Edo Peters | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-24-2008 04:04 PM |
Need a driver for the mbox to work 7.4 LE pro tools on vista | masta1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-18-2008 02:20 AM |
Updated to Intel/updated plugins don't work | Mixtrix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-09-2007 07:59 AM |
SSD..updated firmware, now light just flash, doesn't work!! HELP!! | maxtraxstu | Pro Tools TDM Systems (Mac) | 6 | 01-18-2000 03:52 PM |
