Old 10-14-2013, 04:22 PM
jamieguitar jamieguitar is offline
Default Quanitize not working right PT11
When I use PT 11.0.2, Quantize gets the rhythm right(-ish hard to know for sure) but it makes the notes so short that you can barely hear them. Using the same setting on PT 10 10.3.6 does not produce the same results at the same settings. I had the problem with the original release of PT 11, and decided to update hoping that would help. It didn't. VERY frustrating, as I am loving PT 11 now that the AIR instruments are AAX. I have tried numerous settings - ever trying "note off". Since PT 10.3.6 works, but PT 11.0.2 does not, ....that must mean something . Anybody have thoughts here?
I tried reinstalling the driver, starting from a new session, using a different drive, deleting preferences.....and, I have searched all over and see no solution. Help please!
Eleven Rack
Pro Tools 11.0.2
2.80 gigahertz Intel Core i7 860
64 kilobyte primary memory cache
256 kilobyte secondary memory cache
8192 kilobyte tertiary memory cache
64-bit ready
Multi-core (2 total)
Hyper-threaded (4 total)Windows 7 Ultimate (x64) Service Pack 1 (build 7601)8 GB RAM
Board: Dell Inc. 0X231R A00 Bus Clock: 133 megahertz
Last edited by jamieguitar; 10-15-2013 at 02:42 PM. Reason: Changed "note on" to "note off" - what I had intended to say.
Old 10-14-2013, 09:22 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Quanitize not working right PT11
I thought I had to be on 10.3.7 to have the dual install?
Daniel
Old 10-15-2013, 09:13 AM
When I first download PT 11, 10.3.6 was the most recent version. I didn't update it when I updated PT11. I don't know that it matters, but thanks for the response.
I'm bumming out here that nobody seems to know what my issue is and what my next steps are. I don't want to be without quantize in PT 11....
Jamie Ward
Old 10-15-2013, 09:40 AM
YYR123's Avatar
What kind of notes? Audio or midi?
Check your grid setting b/t the two versions
The smaller the grid the tighter quant tries to fit them into the spaces (at least for midi notes) fwiw I don't use quant on audio I use EA - elastic audio
Daniel
Stig Eliassen's Avatar
It works fine in 11.0.2 here, but I use Macs. In the What to quantize section, you have Note on and Preserve note duration checked, yes?
Old 10-15-2013, 10:52 AM
Sorry, I completely left off this info. I am talking about MIDI. Thanks for the idea of grid settings. I thought it was only the info entered into the quantize box that was relevant. However, now I can't wait to get home and try that! This has been driving me absolutely crazy! I'll post back when I try. Work really gets in the way of what I really want to be doing!
Updated: Changing the grid settings didn't have any effect, unfortunately.
Jamie Ward
Old 10-15-2013, 10:53 AM
Attachment 888
Yes, I do. I tried all combinations just for the heck of it, but it didn't make any difference. Thank you for the reply.
Jamie Ward
Old 10-15-2013, 02:46 PM
I uninstalled and reinstalled PT 11.0.2. Same issue! Please, anybody have any other thoughts? I'm totally out of ideas at this point.
Jamie Ward
Old 10-15-2013, 06:19 PM
YYR123's Avatar
Nevermind
Daniel
Old 11-10-2013, 09:37 AM
This question was asked a few weeks after me and the solution was found. Thanks, Dizzi45Z!
Here's the link: http://duc.avid.com/showthread.php?t=346582
Jamie Ward
Has anyone working Skooch with PT11 briancares Pro Tools 11 35 09-23-2023 08:32 AM
PT11 Hui and Motu Traveler not working Azulin Getting Started 12 03-13-2014 08:20 AM
pt11 and Mbox2Pro not working Tbob macOS 1 11-19-2013 09:00 AM
Artist Mix Not Working in PT11? Chingy Pro Tools 11 9 07-01-2013 10:56 PM
How are AAX VI's working out in PT11? jumle AAX Plug-ins 6 06-24-2013 01:45 PM
