Old 01-01-2024, 05:06 AM
mab780 mab780 is offline
Default Re: no firmware on XMON
I'm having exactly the same problem with my XMON.
It looks like the unit has lost its firmware, but when I try to update it for my D-Command, all I get is 'Error 1'
Does anyone have any idea how I can get the unit back in working order?
Old 01-02-2024, 01:31 AM
AREED AREED is offline
My problem was the 15 pin cable from the Xmon to the DCommand. It was not the original Digidesign cable and needed some pins pulled to operate.
https://duc.avid.com/showthread.php?t=387208
Old 01-09-2024, 01:37 AM
patrem93 patrem93 is offline
hi,
I have the xmon to which I would like to connect two stereo sources. in the manual, I clearly understood that I had to use the stereo inputs 1-2 (L-R) and 3-4 (L-R) on the jack but this is the only jack for which there is no the connection diagram on the pins? is the same wiring as for the cue inputs socket
1 pin 24-12-25 Left
2 pins 10-23-11 Right
3 pins 21-9-22 Left
4 pins 7-20-8 Right?
Thanks for your help
Best upgrades from Paris
Patrick
Firmware Updates lost fader pack. Firmware or personality? Oakdale Post ICON & C|24 0 03-23-2013 12:37 AM
xmon firmware update confusion Igotsoul4u ICON & C|24 1 04-18-2006 03:46 PM
XMON Firmware Update Avid General 0 12-15-2005 08:15 PM
Xmon and new firmware causing other problems?? mtung ICON & C|24 5 12-12-2005 12:25 PM
XMON Firmware Update Avid ICON & C|24 0 12-09-2005 10:51 PM
