Old 12-13-2016, 05:10 PM
Barry Johns Barry Johns is offline
Default X-Mon Will any DB15 Cable Work
Is there a reason why any DB15 cable will not work properly when connecting the D-Command to the X-Mon? As long as each pin is wired to the same location on each end of the cable, why would just any old cable work?
One like this as an example?
https://www.amazon.com/Your-Cable-St.../dp/B002HYJW6U
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 12-13-2016, 05:19 PM
arche3's Avatar
arche3 arche3 is offline
Default Re: X-Mon Will any DB15 Cable Work
It will work. You need to snip a couple pins on one side so it doesn't make the connection. If you do not it won't work. I can have a look at my cable tomorrow that I made and tell you which pins to snip.
Sent from my SM-G935V using Tapatalk
Old 12-13-2016, 05:31 PM
That would be great!
Old 12-13-2016, 07:14 PM
arche3's Avatar
Old 12-13-2016, 07:15 PM
arche3's Avatar
URL=http://www.image-share.com/ijpg-3393-145.html][/URL]
Old 12-13-2016, 07:17 PM
arche3's Avatar
Use a pair of needle nose pliers and grab the male pins marked in red. Twist and pull them out. This should make the control cable work. I made this for my xmon and d control. After I misplaced the control cable.
Old 12-13-2016, 07:18 PM
arche3's Avatar
This is the manual I made for myself. Lol.
Old 12-13-2016, 07:22 PM
I've been reading more and more about this. I found this wiring diagram:
So if I take whats on this, and what you've indicated, it looks like the following pins are not supposed to be wired on either end of each connector:
3
4
7
11
12
It looks like the only pins that are wired are pins number:
1
2
5
6
8
9
10
13
14
15
Now, on the first diagram, there are circles in between certain numbers, not sure what that indicates, but I applied it to my rudimentary drawing here:
So looking at both the pinout wiring diagram as well as the fact that you have indicated that removing certain pins from the cable connector, it appears that the following pins can be snipped to make the cable work:
3
4
7
11
12
Old 12-13-2016, 07:25 PM
Funny, I actually typed my reply before I saw that you posted this, which it appears, my research was correct! Maybe I'm not so dumb after all!!!
Old 12-13-2016, 07:26 PM
arche3's Avatar
Ha ha. Your drawing. But it is the same as what I did. Solved!!!!!!! I bought a 15 ft db15 cable for my diy. I'm sure you can go longer.
WTT: flex cable for short digilink cable tripstation Buy & Sell 1 08-21-2012 01:22 AM
Replacement cable for SYNC IO (NOT all work) Drexelrecording Pro Tools TDM Systems (Mac) 5 11-16-2009 03:24 PM
CS604 5 node TDM ribbon cable won't work with my "MIX cards" Little Fella' General Discussion 0 01-30-2003 09:06 PM
Is cable for 24|Mix -> 882/20 standard SCSI-2 cable? Last Legend Pro Tools TDM Systems (Mac) 2 01-18-2003 12:36 AM
Digi 001 I/O Cable Question (need longer cable) M@tt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-16-2001 01:47 PM
