omni/native latency vs mbox pro latency
Hi everyone.
I currently have the Mbox Pro wich has almost zero monitoring latency while tracking through the mixer. I might get a deal on omni/native but have concerns regarding the latency on this system. I wonder if native has lower latency than the direct monitoring of the mbox, or if it also has the possebillity of direct monitoring ? Iv grown accustomed to the direct monitoring of mbox pro and leave the buffer size at 1024. It would be bad if the latency is not better or atleast equal to the mbox pro direct monitoring. Also i will have to track beside the omni because of my small room so im wondering if the fan noise is still a problem. Third, might this be a bad time getting the omni/native combo ? |
Re: omni/native latency vs mbox pro latency
The latency should actually be better, not worse. Since HD Native is PCIe based, and because the card handles processing of the I/O, it actually reduces latency vs. firewire/usb.
Plus, the new HD converters, including the Omni, are a more advanced design, with a simpler path to the A/D converter, so they actually convert analog to digital faster (this is mentioned in the Avid promo videos about the new HD interfaces when they came out). And the experience of users has confirmed this. So a buffer of 128 feels more like 64, 64 feels more like 32, etc. And, it also has a low latency monitoring mode, similar to the other Avid/Digi interfaces. In this mode, plugins on the tracks you're recording onto are disabled. And it's only for 2 tracks at a time, which is probably not an issue if you're just recording stuff yourself. The only thing is that the Omni doesn't have any built-in DSP effects like the Mbox Pro does. As for the fan noise, it seems to be different for different people, and how they've got it set up. I've been able to hear one at my local Guitar Center and it's very quiet, perfectly fine for tracking near it. The Mac Pro on the floor next to it is actually louder (and that's not very loud). Also, this is a great time to buy the HD Native/Omni bundle, because of the current special of $1500 off. That price is cheaper than any trade up deal they've done. |
Thanks nst7.
I just found the following about direct monitoring in the omni manual on page 34. http://akmedia.digidesign.com/suppor...825.pdf#page38 Quote:
In this case it will be like my mbox pro and just what im looking for. Timing while recording wont be an issue. In this case I could actually set and forget the buffersize in pt to 512 or 1024 because ill be using direct monitoring while tracking instead? |
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
No. I dont track with plugins. I always track dry.
I use direct monitoring on my Mbox Pro. Wich i belive means the mic input is directly routed to the output (headphone) without going through the computer and PT first. To my ears this direct monitoring has much less audible latency than low latency monitoring has. Atleast on my mbox. I guess it would be equal to plugin a mic into a mixer and monitor it on the mixer output (=no latency). If you se my second post above it seems like also Omni has this feature (se page 34 in the manual). Just want to have someone else confirm this. Infact I dont se the use of low latency monitoring if Omni has direct monitoring capabillities ? |
No direct monitoring with the Omni.
LLM on the nativeHD, and 32 and 64 buffer are excellent as far a latency goes.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest |
LLM is for you then. I use it all the time for tracking and just keep the buffer at 1024(Except MIDI production). Give me a shout on Skype if you have anymore questions.
Shane
Shane
Thanks Shan.
If i understand correctly you are saying omni has direct monitoring through its mixer, but you prefer LLM ? Im guessing there is less or no difference in DM and LLM on omni/native? On my mbox pro there is a big difference between DM and LLM. |
Still can't get Low Latency Monitoring With My HD Native Omni! | mmk | Pro Tools HDX & HD Native Systems (Mac) | 8 | 04-10-2020 01:19 PM |
HD Native latency | stevegalante | Pro Tools HDX & HD Native Systems (Mac) | 6 | 03-17-2014 11:49 PM |
PT HD Native & HDX / latency? | kirkbross | Pro Tools HDX & HD Native Systems (Mac) | 13 | 08-24-2013 09:48 AM |
HD NATIVE vs HD TDM latency | James Drake | Pro Tools 10 | 20 | 06-19-2012 04:27 PM |
HD Native latency | CamM | Pro Tools HDX & HD Native Systems (Mac) | 2 | 11-30-2010 07:02 PM |
