Old 02-22-2012, 04:45 PM
tekk tekk is offline
Default Macro Automation Control
Is there any way to have one automation track control multiple parameters in Pro Tools, whether natively through Pro Tools or through a plug in? I've used the macro plug-in that comes with Ableton and it is a dream, and it would save me so much time if I could get similar functionality in PT.
I apologize if this is in the wrong forum. Thanks for any help.
Old 02-22-2012, 04:58 PM
Diccer Diccer is offline
Arrow Re: Macro Automation Control
There is a way to have macro controls.
Get the Max for Live external hardware for macros plug in and run it in Ableton which is in Master Mode
You could record the midi in Pro Tools or Ableton
http://www.maxforlive.com/library/device.php?id=54
Then run Pro Tools as a Rewire slave using the IAC midi bus
http://duc.avid.com/showthread.php?t=313749
You can either record your audio in PromTools or Ableton with virtual audio buses
Just Run Pro Tools as a Rewire Slave/Run Parallel.. its easier than you think. Example- RME TotalMix and the IAC Midi Driver
Old 02-22-2012, 05:05 PM
Default Re: Macro Automation Control
Thanks, but personally that sounds too complicated for the payoff. Might just jump ship to ableton.
Old 02-22-2012, 05:14 PM
I recommend jumping, Have found once you've had a taste of that control there's no going back..
[IMG] code is Off
I need help writing an Insert Macro KeyplayerG Artist Series 2 02-05-2014 06:01 AM
Macro Utlity conundrum spiggy macOS 4 01-27-2014 07:21 AM
Macro softs fabqui67 Tips & Tricks 0 04-07-2005 01:26 AM
macro tea4chew Pro Tools TDM Systems (Win) 0 06-03-2004 04:11 PM
Recommended Macro Program? Roi Huberman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-02-2001 03:59 PM
