Solo Modes???
So what I want to be able to do is solo a track (or group of tracks) then hit solo on another track and have the first lot drop out of solo. ie. so only one track (or group) can be soloed at a time.
This would be really handy when comparing two tracks ie. during mastering when I want to compare volumes etc. Does anyone know how to enable this? Or if it is even possible? I had a look through the Pro Tools Reference Guide but couldnt find anything... Also note that I'm only using LE...
REAPER | Prism Sound Orpheus | ProTools LE 8.0.3 | M Box 2 | Edirol PCR-M50 | Genelec 8020a Monitors + 7050B Subwoofer i7 950, Gigabyte UD4P MoBo, 6GB Corsair RAM, Gigabyte NVidia Silent Cell 9800GT 1GB, Seagate 1TB HDD (2 x 500gb partitions), WD 500gb Caviar Black, Samsung SW2333+, Windows 7 Professional 64bit |
Re: Solo Modes???
From Sound On Sound
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Re: Solo Modes???
I fear this may only be for Pro Tools HD... Im only on LE here. When I access the options tab in preferences there are no solo options to select from... I also looked through the other tabs of the preferences window and couldn't find anything.
But the X-OR mode sounds like exactly what I'm after! Have you actually done this in LE?
Re: Solo Modes???
Options up in the main menu bar is what you want. Holding Shift while clicking Solo in other tracks will keep the previous selected when in X-OR mode. Another way to group solo is select multiple tracks, hold Shift+ Alt, then click Solo on one of the selected tracks. You can also have the edit cursor placed in more than one track and then hit Shift+S. Many ways to do this. Hope that helps. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Re: Solo Modes???
Shane you rock man
There isnt a keyboard shortcut to switch between modes is there? Just out of curiosity...
Re: Solo Modes???
I use Solo Latch (X-OR) when on an Icon (or other control surface) but when mousing around on any other system (usually LE on a laptop) without hardware, I usually just use the "solo track with edit cursor" mode which can be toggled on/off with Shift + S.
This puts a track into solo when you have the edit cursor in the track lane (and on groups, since when click into a member of a group, every group member has an edit cursor, all of them go into solo.) This works like latch behaviour without having to go and click on the solo button on the track as you're working. When I'm done working on checking tracks, I just hit Shift + S again to take me out of that mode. In this case, the Option menu is kept on it's default solo mode since it's being ignored anyway when I'm in the "solo track with edit cursor" mode. Saves a lot of time and annoyance of having to mouse to the far right in the edit window each time I want to move between tracks and I can just keep my eye on the waveform for editing. |
Re: Solo Modes???
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) | charlottewrinch | macOS | 2 | 04-14-2012 05:32 PM |
Solo-Yellow, Solo Clear-Green | Imagine | ICON & C|24 | 1 | 05-14-2011 04:55 AM |
Modes softkey | SBP | ICON & C|24 | 0 | 08-12-2009 12:31 PM |
recording modes | Bryan Cook | Pro Tools TDM Systems (Mac) | 6 | 05-12-2008 07:32 AM |
Input modes | ladewd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-22-2005 11:44 AM |
