Re: Can't hear input sound on headphones
If its soft during playback & u can't hear it recording I think the input is just low & since ur singing u can't hear it; U do have the input selected to MIC correct? I think it seems backwards somewhat on the 003s...
& I could be wrong but isn't the output on that mic sorta low? H.S. ?
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Shane
Crank that GAIN knob up as you need to get the incoming signal up around the halfway point on the meter(on the record-enabled track). If the GAIN knob is up to 3 o'clock and you still have a poor signal(on the meter) then next thing to check is the cable. You need to be using a balanced cable with XLR connectors at BOTH ends(and SM57 into the TRS input would not work).
#16
Hi Shan, Albee and KeyBeeetsss,
Here's where I got with your help. My confusion is how to set up the I/O Selectors so that I will be able to hear the mic on my headphones as I record. Would you please give some clear directions? TRACK 1: Mic SM57, input gain knob the front panel of the 003+ at 3 o'clock I/O (here's were I need help) Audio input path selector: (what do I input here?) Audio Output Path Selector: (what do I input here?) The mic is in input 1 (on the back of the 003+) with an XLR cable. THANKS!!! |
#17
Its pretty cut & dry.. Since ur Mama we'll go easy
But yeah, if the Mic is going into input 1 then thatz what u would set the input to on that track...ur output should be already(defaulted) @ 1-2... & it was probably a mistake & actually wouldn't make a matter anyway because u can't put an input on the output, but u asked, Audio Output Path Selector: (what do I input here?) just re-read that
#18
Create a mono AUDIO track. Select input 1 as its input, Put it in Record-ready. Plug the mic into input 1(XLR jack). Turn the GAIN knob to 12 o;clock for the moment. See if the mic is reaching the track(ie the meter moves when you talk into the mic). If so, adjust the GAIN knob so the meter hits near the middle or slightly higher. If the meter does not move(ie no input signal) hit the MicDI switch to change it. One position should work so you got a 50-50 chance of getting it the first time
#19
#20
I created a mono track. SM57 on input 1 XLR Gain knob at 12 o'clock Record enabled the track I/O: Input selector "In 1" Output selector "Out 1-2" (default) I see the meter moving. I DO NOT HEAR THE MIC ON THE HEADPHONES. If I hit play and record the track, I can then playback the track and hear it. I just can't hear it when it is record enabled and I am testing the level. Any thoughts? Thaks for your patience. |
Can't hear myself in my headphones while recording | rtebel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-04-2012 07:28 AM |
Cannot hear Pan in headphones | John V. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-15-2007 06:14 AM |
Hear the input on headphones? | possumday | Pro Tools M-Powered (Win) | 1 | 10-05-2007 08:04 PM |
HELP!!! CANT HEAR INPUT SOUND | sbio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-09-2007 01:28 AM |
I want to hear metronome in headphones only... | DanZ | Pro Tools TDM Systems (Mac) | 4 | 10-07-2006 10:10 AM |
