Avid HD ASIO Driver Locked Sample Rate
I am trying to use my HDX Card with the Avid HD ASIO Driver with 3rd party applications in Windows 7.
I've tried with both Sequoia & Reaper using driver versions 10 & 11.0.2. The issue I am experiencing is that the Avid ASIO HD Driver will not change from 44.1k Sample Rate. Has anyone else experienced this? Theories are also welcome. Thanks, Keith Moore
Pro Tools HDX 2021.6.0 Lynx Aurora 16 Ross Martin PCM4222 Ross Martin Super Beast Apple Mac Pro 8 Core 2.66Ghz 16GB RAM OSX 10.14.6 http://www.keith-moore.org |
Re: Avid HD ASIO Driver Locked Sample Rate
I thought someone would have jumped in by now, so I'll take a shot in the dark here
First off, how is the system clocked? Any external clocking at play? Next, have you tried going to the clock settings first thing after boot?(wondering if Pro Tools is not "letting go" of the hardware). Back a few years when I was having issues getting not-PT audio to play thru the 002/003 interfaces, I sidestepped the issue completely by feeding optical SPDIF from the motherboard, and running that to a Presonus Central Station. I just hit the digital button on the CS when I need to hear any audio outside of PT and I matched the volume in the sound properties settings. Food for thought
Thanks for chiming in. My hardware setup is as follows: Lynx Aurora 16 (LT-HD Card connected to Avid HDX Card) Ross Martin Audio 4 x PCM4222 AD (This is my master clock, BUT i have the same issue with the Lynx as the master clock as well) Ross Martin Audio SuperBeast AD Behringer SRC2496 Once the Avid Driver is engaged it tried to put the hardware into 44.1k. I can see the 44.1 led on the lynx flashing periodically. This occurs in both Sequoia & Reaper. I have the option of going USB or Optical into the Ross Martin DA but I feel that may be a compromise.
Is windows using the HDX for system playback?
I swear I read on here that someone else was having this issue and they were told to switch the system playback to something else instead of the HDX Card and that allowed them to change sample rates. Sorry I'm on my phone or I'd try and dig up that thread.
www.montabonsound.com www.29counts.com Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection |
Just found it, it was the other thread you posted.
http://duc.avid.com/showthread.php?t=346022 Guess it didn't fix the issue.
Any other insight out there?
You can also click on that area to access the audio device settings directly. Let me know if that works. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Thanks for chiming in. I followed your instructions with Reaper and was in the end able to make changes with the Avid driver following. However, following the same procedure in Sequoia did not turn out successful. Once I switch to the Avid ASIO Driver the hardware immediately switches back to 44.1k Any other suggestions?
HW device is different sample rate AVID | john1192 | macOS | 3 | 10-15-2013 11:41 AM |
Sample rate in PT LE 8 forced to External (locked to 44 khz) after installing VENOM! | Fredy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-29-2012 01:59 PM |
Sample rate in PT LE 8 forced to External (locked to 44 khz) after installing VENOM! | Fredy | Pro Tools M-Powered (Win) | 0 | 12-26-2012 09:01 PM |
ASIO one or more usb ports sample rate not supported | trev27 | Pro Tools SE and Essential (Win) | 2 | 12-06-2012 03:50 PM |
ASIO driver sample rate question | smazur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-24-2008 11:20 PM |
