#21
Re: Track/"Channel Strip" Presets DO exist in Pro Tools, apparently...
#22
With a HDX rig and TDM rig here I thought we were at the top of the tree, didn't realise SE was where it was all happening. Our studio has a few Avid contacts so i'll get them firing a few emails over to see if we can make this happen, at least we know there's little excuse to hold this feature over to a probable paid upgrade (hello pt11)
It's the gift that keeps on giving today - seems its not just limited to single tracks, you can group say an omnisphere with 8 midi tracks, or a 5 instrument setup with sends etc, export selected tracks, rename to ptxt. Then selecting in the new preset calls them all up , a massive time saver, and so much more workflow friendly than importing session data. only small problem i've found with this is if you include separate AUX's to access say the omnispheres plugin outputs 3+4, 5+6 etc they come back greyed out in the first instance til you reselect. A small price to pay... there's a lot of backslapping heading towards PTPhillip today. |
#23
Weird, I can't get it working here. Doing it to the letter.
#24
Over here it works only IF I created subfolder(s). If I save it directly into the "Track Presets" folder, nothing shows up
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
#25
Yeah, that was it, thanks.
#26
This is promising. Hopefully it will be fully implemented in Pro Tools 11. It is really a time-saver in Logic, especially when you want to save a channel setting and mess with it with the ability to easily recall what you had set up to A/B. This would be a nice feature in Pro Tools.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
#27
Great find! Just shows it's easy to implement... Avid should have done this YEARS ago.
THANKS for figuring this out in the meantime.
johnomix.com |
#28
On Windows 7, make sure "Hide extensions for known files types" is unchecked under Folder Options in Explorer. Also, subfolders need to be created for this to work. The PT shortcut keys in the New Track window are also confirmed working on PC. These Track Presets will also work with groups of tracks, providing they're selected when doing the save. I'm currently wrapping up a utility app on PC that will automatically change the extension to .ptxt after saving the preset in step 5 above, thus saving one from manually editing the extension and making this fully functional. It's a beauty to see. Can we get plug-in chains now Avid? Something of note, the extension works as .ptt or ptxt. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#29
http://www.pro-tools-expert.com/home...pro-tools.html Method #1: -In Applications > Avid > Pro Tools, create a folder titled Track Presets. Inside of that, create folders for separate categories (this is necessary). -In Pro Tools, select the track(s) that you want to use as a preset. -Choose "Export Selected Tracks as New Session" from the File menu. -Press OK in the resulting dialog. -Choose your location (inside of a subfolder within Track Presets). -In the Finder, change the extension of the session from .ptx to .ptxt or .ptt. -Voila! Method #2: -In Applications > Avid > Pro Tools, create a folder titled Track Presets. Inside of that, create folders for separate categories (this is necessary). -In Pro Tools, make a blank session then create and configure tracks (including inputs, outputs, names, sends, volume, pan, plug-ins, etc) as desired. -From the File menu, choose Save As Template. -Choose "Select Location for template" -Navigate to a folder within the Track Presets folder (or create a new folder in Track Presets). -This will create a .ptxt file automatically (using the Save As Template function) Once your templates are saved to folders within the "Track Presets" folder, they will appear as options in the New Track dialog below the normal track types (audio track, aux input track, etc). You can still use Command + Down/Up to switch through these and Option Command Down/Up will switch between multiples in your sub-folders. |
#30
I can't believe that Avid create this track templates for the SE version and did not enabled in all the other versions or even just make the other users aware of this function!!!
Just crazy. Anyway, this is a great finding and a real time saver! Thanks for sharing! Davide |
Shortcut for "view channel strip" command? | Zakazastar | Tips & Tricks | 22 | 08-25-2014 10:13 AM |
"Channel strip presets / storage" in PT11 | yeloop | Pro Tools 11 | 2 | 07-25-2013 06:35 PM |
"Fatal exception has occurred. Pro Tools must exist" | Mattlewis | Windows | 3 | 07-25-2013 10:48 AM |
Problem "apparently" finally solved; No more mouse freeze! | dkrausz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-15-2002 08:00 PM |
No "Channel Strip" For PC | B.Ray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-30-2001 10:38 AM |
