Old 07-17-2013, 05:09 PM
Artist PM's Avatar
Artist PM Artist PM is offline
Default Help us help you
Hi guys,
We are having trouble reproducing issues in our test studio. I've put together some questions to help us isolate issues. If you can help us by answering these questions we can get to a reproduction and resolution.
http://www.surveymonkey.com/s/R6KM2GZ
Old 07-18-2013, 10:53 AM
DanielEUCON's Avatar
DanielEUCON DanielEUCON is offline
Default Re: Help us help you
IMPORTANT!
We are trying to track down a specific issue related to the EUCON 3.0 release for Artist Series. Please only respond to this survey if you are seeing the following issue:
- Pro Tools 11 fails to connect/populate the Artist Surfaces. Surfaces do connect to EuControl.
This issue is described in the following thread(s):
http://duc.avid.com/showthread.php?t=341036
http://duc.avid.com/showthread.php?t=340362
Old 07-21-2013, 12:16 PM
Emcha_audio's Avatar
Emcha_audio Emcha_audio is offline
Not working for me on either pt 10.3.6, pt 11 or pt 11 HD. On windows 7 Ultimate.
Manny.
Wave-T.com
Old 07-22-2013, 09:15 AM
PM sent
Old 07-23-2013, 01:30 AM
ha2dorff ha2dorff is offline
Worked for me (so far):
1. Uninstalled version 2.7.1
2. Installed version 3.0.
3. Both PT 10 and 11 started fine with my artist gear (2 x Mix, Control and Transport).
4. Turned Mac off. Waited a minute. Turned Mac on.
5. Both PT 10 and 11 DID NOT start with my artist gear.
6. On EUCON Preferences: Clicked "Stop". Waited 30 sec, and clicked "Start".
7. Both PT 10 and 11 started fine with my artist gear.
8. Turned Mac off. Waited a minute. Turned Mac on.
9. Both PT 10 and 11 started fine with my artist gear.
Old 07-23-2013, 02:54 AM
Antonio Escobar Antonio Escobar is offline
I have the same issue, but I have to stop-start every time that I start the Mac.
Old 07-23-2013, 06:23 PM
We have some additional questions, some of these may seem redundant or simplistic however they will clue is in to the root issue that is causing the startup failure.
1. After rebooting and before starting ProTools, or any other DAW, is the MC_Client application running on your system?
- Use spotlight to open Activity Monitor.
Search for "MC_Client".
- If not there make sure the drop down next to the search box is set to "All Processes" before answering "no").
2. Is EUCON configured to start automatically on system boot?
- Go to System Preferences, EUCON. There's a button next to the "Delete" button, does it say "Start" or "Stop"? (NOTE: Start means that EUCON does NOT start automatically, Stop means it DOES start automatically)
3. Do you launch EuControl manually after a reboot?
- If yes to 3., do you start it before or after launching ProTools?
Sent from my iPhone using Tapatalk 2
Old 07-24-2013, 08:29 PM
Jerry Woolsey Jerry Woolsey is offline
[QUOTE=DanielEUCON;2066077]We have some additional questions, some of these may seem redundant or simplistic however they will clue is in to the root issue that is causing the startup failure.
Yes it's running.
It says stop.
I have to stop and re-start the service to get it to work, then run Pro Tools.
Hope this helps,
Jerry Woolsey.
Old 08-01-2013, 07:02 AM
GuyPicks GuyPicks is offline
[QUOTE=Jerry Woolsey;2066502]
Yes it's running.
It says stop.
Hope this helps,
Jerry Woolsey.
exact same issue here.
My System
Mac mini M1
OS X 11.6.4
PreSonus 1824c
Faderport 16
Pro Tools Ultimate 2021.12
Studio One 6.5 Pro
Logic Pro X
Old 09-26-2013, 12:38 AM
Basstian Basstian is offline
Same here.
OS 10.8.4
PT HDN 10.3.7
PT HDN 11.0.2
