Old 06-22-2013, 12:53 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Eucon 3 not happy with 10.3.6 and 11
I just upgraded 10.3.5 to 10.3.6, and added 11.
Downloaded Eucon 3, doesnt work in either PT version.
Yes, icon is black, computer, and surface are loaded.
Yes, Eucon is activated in PT.
Communicates with PT, as the scribble script changes when I load and unload Eucon in peripherals.
IMDB
Old 06-22-2013, 01:06 PM
Default Re: Eucon 3 not happy with 10.3.6 and 11
Hmmm???
I originally downloaded the one that Danny Caccavo linked to.
Just downloaded the one on the Avid/Euphonix login site, and it works!!
IMDB
Old 06-22-2013, 05:44 PM
ArKay99 ArKay99 is offline
Thanks for the info. I guess I'll have to play Russian Roulette and go to iLok and do all my stuff. now... no excuses...
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2.
Old 06-29-2013, 05:41 PM
robertg robertg is offline
Why don't you at least run snow leopard? Jesus Christ, then you would only be FIVE years behind.
I don't understand why people like you are so scared to update. Apple is not Microsoft, you could probably go all the way up to mountain lion with zero problems.
Is it because your mac is too old? Get a new one!
Old 06-29-2013, 05:55 PM
He is running Lion. Are you reading Pro Tools 10 versions as OS X versions? Jesus Christ why don't you read the posts more carefully before lighting off
But still OS versions may well be an issue. System requiremnet for Mac for Pro Tools 11 is 10.8.4 (Mountain Lion). If you guys want to be test pilots with Pro Tools 11 I would really ought to try to be on a supported OS.
Old 06-30-2013, 01:58 PM
DrFord's Avatar
DrFord DrFord is offline
I never updated OS past 10.6.8 because I didn't want to loose my Kensington Mouseworks. Plus all my programs run fine...
Now if someone has a replacement for KMW that runs on the current OS platform I will upgrade... but I don't want to loose my button functionality doe PT editing. Huge time saver when quantizing drums.
I also am having the same connection issues with my EuCon 3. Glad to know I'm not the only one.
Should we all just install the EuCon 2.7.1?
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Old 07-01-2013, 02:09 PM
silverhammernz silverhammernz is offline
I'm having to reinstall the Eucon software every time to make it work. I'm on 10.8.4 and running 10 & 11. I've cleared out the prefs several times. Each time I start up, EuControl shows the Artist Control & Mix as connected but they don't work until I re install the EuControl software. This happens no matter if I open 10 or 11.
Old 07-01-2013, 03:18 PM
1m1 1m1 is offline
I replaced KMW with ControllerMate from Ordered Bytes several years ago and have never looked back. I highly recommend it.
Old 07-01-2013, 05:56 PM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
Just checked it, looks pretty neat. Thanks for the info!
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Old 07-01-2013, 06:07 PM
1m1 1m1 is offline
I loved KMW in Mac OS 9, but then they removed the functionality for using modifier keys with the mouse clicks on the jump to OS X. That's when I went to ControllerMate and it's been a really good and stable piece of software. I also made the move to a Logitech mouse because there was a lag with the Kensington mice. I was constantly selecting something other than what I intended because the response was too slow. Just make sure you don't install the Logitech Control Center if you use a Logitech mouse because it will conflict with ControllerMate.
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 01:37 PM
Happy Belated Birthday, Eucon 2.6.2!!! Slave2TheLight Artist Series 114 03-26-2013 08:49 AM
Eucon PRO 2.7, seriously? ErikGuldager System 5 4 03-08-2013 07:11 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
