#171
Re: Fine breakpoint adjustment change in 12.6 = Showstopper
Command now does the same thing in both grid and slip. In that sense, editing behavior is actually more consistent in 12.6 than previous versions. |
#172
But when you work on numerous systems (and numerous versions), this change brings along a nightmare of inconsistency. If we keep this change, we must have a preference to revert it to legacy.
#173
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#174
Are there any differences, functionally, between slip mode and slip-grid combo mode in previous versions? They seem to be identical.
#175
Please - this is crazy. For example - The behavior for creating and moving a breakpoint in slip mode is nuts. Command + click is require to add the breakpoint, but if you try to move it the point will snap to grid unless you add option key. Former setup was more elegant (simple) and consistent between modes. I don't think this was a well conceived change. We already had simple way to change modes via F keys. no need for additional modifiers to force or defeat grid.
PLEASE allow legacy preference!
http://www.ainsliegrosser.com/ MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio |
#176
I'm on PT11HD so don't have this issue but I must say I'm completely lost after reading this thread. So many pages and arguments :)
I suppose that the golden rules is "Don't break something that works" and in that regards and in many others the best option will be to revert back to the original behaviour. But one thing is certain, after reading this thread I want to learn about Basstian's workflow in regards of editing DX and using clip gain breakpoint adjustments. |
#177
No, it doesn't. It let's the node be dropped in on target, but does NOT allow for fine adjustment. You have to use Shft+Cmd to create the node, then release it and then press Cmd to do the movement. It's absolutely broken. |
#178
I work with 10, 12.4, and 12.6 daily. This is a ludicrous change and simply needs to be an option to revert to proper (AVID will say Legacy) command or reverted completely. I have no idea how this could have possibly made it through beta without an uproar.
My studio partner is teaching a college Pro Tools course right now that requires PT10 or later. Students are mixed and this is throwing yet another wrench into the works. |
#179
In grid mode, unrestricted fine adjustment exclusively snaps to grid, which also makes no sense if command is supposed to toggle to slip mode. Long story short, 2-way seamless on-the-fly grid/slip toggle is a awesome idea (and absolutely doable in a way that preserves legacy editing). Avid just completely, utterly FUBAR'd it on first attempt. |
#180
Fine Fader Adjustment On iPad? | producedbyriot | Avid S1, S3, Dock and Control App | 4 | 09-10-2016 01:00 PM |
Fine Adjustment on AAX seems to be Broken? | Neil Pickles | AAX Plug-ins | 4 | 06-07-2013 01:39 PM |
fine adjustment of breakpoints not working | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-03-2010 06:42 AM |
Fine volume adjustment | gbours | Pro Tools TDM Systems (Mac) | 3 | 05-02-2006 07:23 PM |
Strip Silence and Fine Adjustment... Still a bug? | SimpleNatureSpirit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-21-2004 11:22 PM |
