Old 08-26-2022, 09:52 AM
dominicperry dominicperry is offline
Default bx_console N doesn't show in EQ curve.
I've noticed the bx_console N doesn't show an EQ curve on the mixer strip. Am I doing something wrong, or is this a limitation of the plugin, and if so has anyone asked PA to add this kind of thing?
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 08-26-2022, 10:50 AM
sw rec sw rec is offline
Default Re: bx_console N doesn't show in EQ curve.
Some of them don’t “report.” Same thing with the compressor “gain reduction” display next to the meters on the channel strip. Some of them don’t have that feature .
Old 08-27-2022, 06:24 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Dominic
Make sure you have the latest version of the plugin as it may have been implemented since you installed the version you are using.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 08-29-2022, 09:05 AM
daeron80 daeron80 is offline
It's an emulation of an analogue channel strip, so I wouldn't expect it to. It's more about evoking the magic of the circuitry than about clinical frequency response.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Metric Halo Channel Strip won't show the EQ curve in the Mix Window JCBigler AAX Plug-ins 1 04-15-2021 07:29 AM
Fader's LEDs don't show the volume curve anymore. bucha Avid S4/S6 1 01-03-2018 10:31 AM
Why doesn't 10.3.4 show as an update strangedogs macOS 2 03-14-2013 03:15 PM
AMS doesn't show up crawfish Pro Tools TDM Systems (Mac) 2 06-18-2007 04:18 AM
EQ III Doesn't show up tonicjeff Pro Tools TDM Systems (Mac) 2 04-20-2005 12:11 AM
