Old 01-28-2014, 07:25 PM
JChris JChris is offline
Default Eleven Rack Stand Alone Editor Help!
I loaded The Stand Alone Editor on Sunday afternoon Jan 26th.
It worked for about an hour. The next time I tried to load it, just after the screen shows the editor loading up, it minimizes itself to my task bar and then can't be maximized again. I have tried reloading everything multiple times with no luck. I have Win 7 SP1 and the 1.16 AVID Drivers. Have any of you experienced this issue? If so, what else can I do to try and fix this?
J.
ADMIN EDIT: Please see the Knowledge Base Article & Bug Report
Last edited by DigiTechSupt; 08-21-2015 at 01:14 PM. Reason: Merged similar threads and added links.
Old 01-28-2014, 07:49 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack Stand Alone Editor Help!
Any error messages?
Is the Eleven Rack connected and turned ON?
Are the PACE/iLok drivers installed?
Is the Eleven Rack connected to a USB 2.0 port, NOT a USB 3.0 port?
Have you tried using a different USB port?
Have you tried uninstalling the Editor, re-start the PC and Eleven Rack, then re-install?
Have you read the Troubleshooting and FAQ pages?
http://duc.avid.com/showthread.php?t=350148
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 01-28-2014, 08:27 PM
Yes, I have done all of those things several times. The program works fine on my Laptop PC, but on my Desktop it will not stay maximized. I have tried to contact Avid, but have not heard back yet. I really can't seem to figure out why this is happening on my PC. There has to be somebody that has experienced this issue? I do not get any error messages.
J.
Old 01-28-2014, 08:57 PM
cdvh5150 cdvh5150 is offline
I had the same problem I fixed it by hitting Ctrl, Alt, Delete, than choose open task manager, you will see the Eleven Rack Editor hitlight it and right click, select Bring to Front, now close the Task Manager, and close the Eleven Rack Editor, than Reopen the Eleven Rack Editor,,, This Works for me... hope it helps you....
Old 01-28-2014, 09:32 PM
Benoni's Avatar
Does this happen to you every time you launch the Editor?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-29-2014, 10:01 AM
OK, I got it to work by using the Task Manager. Bringing it to the front and maximizing the screen helped!
Thanks!!!
Old 01-29-2014, 12:15 PM
no Benoni after I fixed it with the task manager it doesn't happen to me anymore... but if it does I know now how to fix it...
Old 01-29-2014, 01:36 PM
Benoni's Avatar
Thanks.
What kind of video card do you have? Nvidia or AMD/ATi?
And this is Windows 7 64 bit correct? Home Premium, Pro, Ultimate?
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-29-2014, 01:38 PM
Benoni's Avatar
Thanks!!!
What kind of computer were you having this issue on? AMD cpu or Intel?
What kind of video card?
What exact version of Windows?
Thanks.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-29-2014, 05:16 PM
I got a cheap Intel Video Card, I using Windows & Pro 64 Bit....
Eleven rack editor freezes baribari Eleven Rack 2 02-17-2014 07:40 AM
Eleven Rack Editor Now Available Avid Technical Alerts 0 01-23-2014 09:02 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Eleven rack stand alone editor Samscasa Eleven Rack 23 02-27-2012 08:45 PM
