Old 01-24-2014, 10:51 AM
Benoni's Avatar
Benoni Benoni is offline
Exclamation Eleven Rack Editor - Info
Download the FREE Eleven Rack Editor - Before installing, be sure to read the FAQ's and make certain your system is compatible.
apps.avid.com/eleven-rack or avid.secure.force.com/pkb/articles/Troubleshooting/Eleven-Rack-Editor
Eleven Rack Editor v1.0.0 Read Me
akmedia.digidesign.com/support/docs/Eleven_Rack_Editor_Read_Me_80929.pdf
Eleven Rack Editor FAQ's
avid.force.com/pkb/articles/faq/ElevenRackEditorFAQ
Before installing, please read the Eleven Rack Editor Troubleshooting Guide for basic information about what could cause problems with the Eleven Rack Editor and what is required to install the Eleven Rack Editor.
avid.force.com/pkb/articles/troubleshooting/Eleven-Rack-Editor
Compatibility
To use the Eleven Rack Editor, you must have an Eleven Rack with Firmware version 2.0.x (the Eleven Rack Expansion Pack).
To check the firmware version on your unit, hold the EDIT/BACK button on the front panel until the options menu appears. Then, use the scroll wheel to scroll down the list, and select Firmware Version with the SW 1 button.
How To Check Firmware Version Video
If the firmware version is older than version 2.0, you will need to purchase and install the Eleven Rack Expansion Pack, available here.
If your Eleven Rack has older firmware, the Eleven Rack Editor may still function somewhat, but the on-screen controls will not correctly correspond with parameters and presets.
Eleven Rack Editor is compatible with the following operating systems:
Mac OS X 10.8-10.8.5 and 10.9-10.9.1 (OS 10.7.5 and earlier are not compatible)
Windows 7 SP1 and Windows 8/8.1 (64-bit only)
Eleven Rack Drivers
Please install the latest Eleven Rack drivers before installing the Eleven Rack Editor.
avid.com/drivers
PACE/iLok
An iLok is NOT required, but there are some PACE/iLok software elements that are required. iLok License Manager software should be installed automatically. If the iLok software was not installed automatically with the Eleven Rack Editor, you can install the iLok License Manager manually from iLok.com
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 01-24-2014, 11:15 AM
Benoni's Avatar
Default Re: Eleven Rack Editor - Info
See the Standalone Eleven Rack Editor in action
Standalone Eleven Rack Editor - Demo (YouTube Video)
One thing you may notice about the Eleven Rack Editor v1.0.0 is that is does not stay on top of other windows when you click away, like to adjust volume or panning in Pro Tools. If you are on Windows 7/8, there is a free app called Always On Top that can stick the Eleven Rack Editor on top.
Keep Eleven Rack Editor (v.1.0.0) on top of other windows (YouTube Video)
Or read about it here
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-27-2014, 05:38 PM
arturocivit arturocivit is offline
Hi, not sure if this is the right place to post this but, I ended upgrading my OS in order to run the editor and all what I got is this:
Any idea guys what might be happening?
Thanks!
Arturo
Old 01-27-2014, 06:23 PM
Benoni's Avatar
[pictures cut from reply]
Thanks!
Arturo
Yep, in post #1 above you will see this:
PACE/iLok
An iLok is NOT required, but there are some PACE/iLok software elements that are required. This should be installed automatically.
If the iLok software was not installed automatically with the Eleven Rack Editor, you can install the iLok License Manager manually.
www.iLok.com
Try installing the iLok Manager and then see if the Editor will launch correctly.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-28-2014, 03:39 AM
And that did the trick, thanks a lot Brian!
Old 03-08-2014, 01:36 PM
DanteDiapa DanteDiapa is offline
Hey I am trying to download the editor but I can only get an error while trying to visit the download page:
"404 - Page Not Found
The file or page that you are looking for cannot be found or has been moved. Please choose from one of the links below or use our search engine to locate the information you are looking for. "
Is it not available anymore or what?
Old 03-08-2014, 01:39 PM
Bruce Paine's Avatar
Bruce Paine Bruce Paine is offline
Admin Emeritus
Looks like a broken link, it should be there at www.avid.com/elevenrackeditor
I'll notify the web team.
Thanks!
Bruce Paine
System Details
Old 03-08-2014, 01:41 PM
Thanks!
Yeah, it is not. I tried on two different PCs with three different browsers haha. And seen other people on youtube saying they can't download at that link either.
I just can't wait to have it \o/
Thanks
Old 03-08-2014, 02:03 PM
Admin Emeritus
Fixed, both www.avid.com/ElevenRackEditor
and
...should now correctly redirect to the download page:
http://apps.avid.com/eleven-rack/
If they don't, just use that last link.
Bruce Paine
System Details
Old 03-08-2014, 02:11 PM
For me they still don't but that last link worked fine, it seems. I'll let you know if something goes wrong before I can get the download. Thanks so much for the quick assistance.
EDIT: cool it is downloading right now.
Eleven Rack Standalone Editor brianiac5150 Eleven Rack 315 02-07-2015 04:53 PM
Eleven rack editor freezes baribari Eleven Rack 2 02-17-2014 07:40 AM
Eleven Rack Editor Now Available Avid Technical Alerts 0 01-23-2014 09:02 AM
