Old 01-20-2009, 10:35 AM
undergroundcubby undergroundcubby is offline
Default D-Show Profile to control HD3 Rig?
Hi All, Can a D-show Profile be used to control an LE or HD rig? Can it be used without the FOH or Mix Rack as just a controller for PT?
Thanks
HD 3 Accel PCI
HP XW9300
192 I/O
Midi I/O
Old 01-20-2009, 04:09 PM
DigiFieldService DigiFieldService is offline
Default Re: D-Show Profile to control HD3 Rig?
Thanks
Hi, thanks for your question.
The VENUE system acts as the interface for Pro Tools via the HDx or FWx options. The D-Show and D-Show Profile control surfaces cannot be used as controllers for Pro Tools.
regards,
DigiFieldService
Old 01-21-2009, 08:53 PM
Nicolas Lowman Nicolas Lowman is offline
You know it would be pretty cool if there was a device that could be made to take a console link in and output the can bus from the console to ethernet. So that you could get control into an HD rig. I would think that if this interface existed, one would then only have to map the controls to the PT interface. It would be pretty cool to be able to use the surface on the road and then also to mix in a PT rig as well. Maybe one day....
Nicolas
Old 01-29-2009, 05:43 AM
BradLyons BradLyons is offline
The best way to do this is a GEFEN box that allows you to send USB and VIDEO remotely. I design a lot of systems and do this for many designs where they don't have someone to run/control the ProTools system. Having the ability to control it from within the console would scare me.....one wrong button, you might shut your recording down.
Thank you,
Brad Lyons
www.howavl.com
Old 02-08-2009, 08:49 AM
JoshRose JoshRose is offline
Post/Studio mixing on the VENUE can work pretty well, even though it can't necessarily be a PT controller. But you can send your PT channels over to the console, and then mix from the console back to PT. This means you'd be using console plugins rather than plugins in PT, but if you have LE like us, that's not a bad thing. We have much better stuff on the console than we have in LE.
I've had some really nice results doing this, and it's a lot faster than starting fresh on a post mix with a mouse and a DAW. I can turn a 2 hour service into a nice post mix in about 2 1/2 hours.
And since your PT faders just sit at 0, you can save the mix parameters on the console, and easily pick up where you left off.
I don't think you can do this without an FOH or Mix rack, however.
Profile/D Show Faders roberts VENUE Live Sound Systems 2 06-30-2023 01:44 PM
D-Show Profile Stuck bandmfp VENUE Live Sound Systems 2 05-20-2013 06:57 PM
Using Midi with D-show Profile Rob Warren VENUE Live Sound Systems 3 10-09-2009 07:55 PM
2.8.x for profile/d-show SteveGam VENUE Live Sound Systems 0 07-08-2009 05:40 PM
D Show Profile as PT controller? lifer VENUE Live Sound Systems 3 10-05-2006 07:12 PM
