Pro Tools 8.0.3 won't load after initial install
Hi everyone,
Have recently received a new work laptop with Windows 7 Enterprise (Sandra report is below) and have been tearing my hair since attempting to install ProTools LE 8.0.3 on my system as per the instructions on the digi website. Sandra Report: SiSoftware Sandra Computer Model : Dell Latitude E5400 Processor Model : Intel(R) Core(TM)2 Duo CPU P8700 @ 2.53GHz Speed : 2.66GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, 64 byte line size, 2 threads sharing Computer Platform Compliance : Intel Centrino Duo 2 Mobile Technology Mainboard : Dell 0D695C BIOS : Dell A15 11/05/2009 Bus(es) : ISA X-Bus PCI PCIe IMB PCMCIA CardBus USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.46GB DDR3 SO-DIMM Chipset Model : Dell GM45/PM45 Mobile Controller Hub Front Side Bus Speed : 4x 266MHz (1GHz) Total Memory : 4GB DDR3 SO-DIMM Shared Memory : 32MB Memory Bus Speed : 2x 399MHz (798MHz) Memory Module(s) Memory Module : Hynix (Hyundai) HMP125S6EFR8C-S6 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Hynix (Hyundai) HMP125S6EFR8C-S6 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : Mobile Intel(R) 4 Series Express Chipset Family (10 SM4.0 533MHz, 32MB DDR3, Integrated Graphics) Graphics Processor Storage Devices Seagate ST9160412ASG (160GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) : 149GB (C:) (D:) TSSTcorp DVD+/-RW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Reserved : 200MB (NTFS) Win7 System (C:) : 70GB (NTFS) @ Seagate ST9160412ASG (160GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) Data (D:) : 79GB (NTFS) @ Seagate ST9160412ASG (160GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) Optical Drive (E:) : N/A @ TSSTcorp DVD+/-RW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell (ICH9M) LPC Interface Controller LPC Legacy Controller 1 : T0 00-00 Audio Device : Dell (ICH9) HD Audio Controller Audio Codec : Integrated Device Tech 76B2h Audio Codec : Conexant 2C06h Audio Codec : Intel 82GL40 [Cantiga] High Definition Audio HDMI Service Serial Port(s) : 1 Disk Controller : Dell (ICH9) Mobile SATA AHCI Controller Disk Controller : Dell SD Bus Host Adapter USB Controller 1 : Dell (ICH9) USB Universal Host Controller USB Controller 2 : Dell (ICH9) USB Universal Host Controller USB Controller 3 : Dell (ICH9) USB Universal Host Controller USB Controller 4 : Dell (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Dell (ICH9) USB Universal Host Controller USB Controller 6 : Dell (ICH9) USB Universal Host Controller USB Controller 7 : Dell (ICH9) USB Universal Host Controller USB Controller 8 : Dell (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Dell R5C832 IEEE-1394 Controller CardBus/PCMCIA Controller 1 : 65532 RL5c476 CardBus Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Send To Microsoft OneNote Driver (300x300, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Adobe PDF Converter (4000x4000, Colour) Printer : HP Universal Printing PCL 5 (600x600, Colour) Printer : HP LaserJet 4200 PCL 6 (600x600, Parallel, Colour) Printer : RICOH Aficio MP 3351 PCL 5e (600x600) Network Services Network Adapter : Broadcom NetXtreme 57xx Gigabit Controller Network Adapter : Bluetooth Device (Personal Area Network) #2 Wireless Adapter 1 : Intel(R) WiFi Link 5100 AGN (802.11g (ERP), TKIP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x86 Windows Experience Index Current System : 3.4 Install happens without any issue then when I double click to load ProTools I get the following error: Problem signature: Problem Event Name: BEX Application Name: ProToolsLE.exe Application Version: 8.0.3.251 Application Timestamp: 4b2c7fc4 Fault Module Name: MSVCR80.dll Fault Module Version: 8.0.50727.4927 Fault Module Timestamp: 4a2752ff Exception Offset: 00024ac6 Exception Code: c000000d Exception Data: 00000000 OS Version: 6.1.7600.2.0.0.256.4 Locale ID: 3081 Additional Information 1: c534 Additional Information 2: c53481d035cf5dd40f4b83083e80c30e Additional Information 3: 5dc2 Additional Information 4: 5dc2a10083db2537c2feb074a696a547 My system is hooked up to my MBox 2 with the Windows 7 drivers. Does anyone have any ideas on how to fix this problem? |
Re: Pro Tools 8.0.3 won't load after initial install
1. BETA. All too common.
2. DELL laptop. NOT a good PT host. 3. Disable wireless. 4. If you ever DO get it to load, it isn't going to work recording to a partition on your system drive. You need a separate dedicated drive for audio. |
I have the same problem with my desktop PC, Windows 7, dedicated audio drive, 8 gig RAM. Does Pro Tools even work with Windows 7? I try to open the program and nothing happens, it isn't even in the task manager. WTF?
Thank you for your reply.
While I know this is a BETA release, I have a Toshiba M750 and a Dell Latitude 6400 both running Windows 7 with a single hard drive and they both have no issues with 8.0.3 and recording using our 003, MBox 2, MBox Mini or Micros. The only real difference between my other laptops and this new work laptop, is that it is a fresh install of Windows 7 and Pro Tools 8.0.3. Considering that PT is not even loading after the initial install, this points to a software issue and nothing to do with the hardware configuration. |
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
"Does Pro Tools even work with Windows 7?"
FIGHTS have been started over that topic...... BTW, napsternova, you really should start your own thread. |
IMPORTANT! You MUST use a secondary hard drive (not your main OS drive) for recording and playback of audio in Pro Tools. Recording or playback from the OS drive is known to be problematic and the cause of many different error types. If you are using your system drive and encountering errors, the first thing you should do is get a compatible drive. USB drives are not supported and are known to be problematic, so please do not use them with Pro Tools. If you're recording or playing back from a USB drive and are getting errors in Pro Tools, please switch to using a compatible external firewire drive or internal SATA/ATA/IDE drive and disconnect the USB drive. Pro Tools supports recording and playback to a secondary drive that meets the following requirements: 7200 rpm or faster 9ms seek time or faster http://duc.digidesign.com/showthread.php?t=193637 And Yes, PT works great with Windows 7. Been using Win 7 since the day it was released. Both 32 and 64 bit.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
+1
Hi everyone,
Have finally discovered what this issue was. As our work machines use roaming profiles by default, ProTools wouldn't start due to this server confirguration. As soon as we started using a local profile it worked fine. |
pro tools 8 stuck at "structure" at initial load | Awesomeworld | General Discussion | 8 | 09-21-2011 01:10 PM |
Initial gripes with PT HD 7.3 Install | kbruff | Pro Tools TDM Systems (Mac) | 5 | 12-29-2007 01:04 PM |
7.3 problem (ahhh!) completing initial load | liberccxx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-20-2006 01:16 PM |
Can't start PT LE 5.3.1 on initial install - XP | zagood | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-12-2003 05:12 AM |
freezing after initial load | arigold | Digidesign Hardware & Software | 1 | 11-29-2000 04:51 PM |
