Recording instrument track to audio track
Using Pro Tools 11, when I try to record an instrument track with say Boom on it to an audio track, I set the Out of the instrument track to Bus 1-2. Then I try to set the In of the audio track to Bus 1-2, but it doesn't give me that option. Clicking input on the audio track gives me options of Audio 1-6. Clicking Bus there are no options; nothing shows.
I looked in the MBox Pro settings, saw nothing to change. Any suggestions? |
Re: Recording instrument track to audio track
Hi
Goto settings and choose i/o and press default on all tabs like in out aux etc and see if that helps Best Regards Christopher
Being in PT 11, I'd do an offline render:
http://duc.avid.com/showpost.php?p=2135648&postcount=9 http://duc.avid.com/showpost.php?p=2135447&postcount=6 Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Worked like a charm. Thanks so much.
I went into Setup for I/O, bus tab, hit default. Then the choice for Bus 1/2 appeared on my Instrument tracks Output, and on the Audio tracks Input.
Apparently I have to do that with previously recorded material to fix previously recorded material. |
I solved this problem. I unchecked Low Latency Monitoring. The manual under that topic warns about the problem. Thanks for your help.
Wondering if rendering a instrument track like lets say Omnisphere is there any latency issues?? If I send the RMX outputs to an audio track I always ending up with lots of latency.
Jimmy Makhaisingh Producer Mix/Mastering Engineer JimJam Studio iMac (Retina 5K, 27-inch, Late 2015) PT11HD HDX /HD i/o Magma Thunderbolt 2.0 Chasis 3T Manley Vari-Mu / MPassive Mastering version Sonnox bundle / McDsp / FabFilter / |
Glad it helped Best Regards Christopher
There shouldn't be any latency after bounce of any instrument if the settings are done correctly. Check HW buffer and low latency etc and see what happens. If I bounce with LLM ON I get strange Caca happen. Best Chris
Instrument track picking up my microphone, but not my audio track. | raddster | Pro Tools 9 | 5 | 01-20-2012 04:11 PM |
Can't Mute or Change Volume on Audio Track and Instrument track | FunkTools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-10-2010 04:40 AM |
Problem Converting Instrument Track to Audio Track | Gorbies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-02-2009 09:11 PM |
bouncing from instrument track to audio track | rolew | Pro Tools M-Powered (Mac) | 5 | 04-18-2009 02:01 AM |
GOING LOONY From instrument track to audio track | Paul Cavins | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-18-2007 04:47 PM |
