Old 02-26-2011, 10:26 AM
Gamling Gamling is offline
Default Dropped notes, sustain problems, random notes
Hello all,
I am using a Yamaha S80 synth through the new Avid Mbox 003. I am attempting to record a very basic piano piece using PT 8.0.4's "Mini Grand".
My problem is that I occasionally get dropped notes and sometimes the sustain pedal doesn't seem to work (comes off too early or doesn't trigger at all).
Earlier today, I also got a random note that just started playing way up high on the keyboard. So, I'm like WTF? I can't really run a recording session with these problems.
Any advice for general MIDI troubleshooting? My OS is Mac OS X 10.6.6 on a brand new iMac, so I don't think it's anything major.
Feedback is greatly appreciated,
Marc
Old 03-11-2011, 12:29 PM
Default Re: Dropped notes, sustain problems, random notes
FYI, I discovered what was causing this... The Yamaha S80 synth sends MIDI clock messages when it is in its default config. I think this is because of the arpeggiator in the synth. This was effectively flooding the MIDI channel to the point where messages were getting lost.
Anyway, I disabled the SeqCtrl in MIDI setup and viola... MIDI works perfectly.
Just thought others might benefit from this information...
PS - MIDI Monitor was how I discovered what was going on behind the scenes. It's a great utility.
Old 04-24-2011, 03:47 PM
bulaboy bulaboy is offline
Thanks so much. I have a kx88 routing through 003 to a motif xs and have experienced similar problems with phantom notes, notes sustaining, ..etc. Much improved since turning off the sequencer control *off* on the motif. Thank you.
Old 04-25-2011, 06:50 AM
Awesome. I'm glad this helped someone. I was pulling my hair out!
Old 02-10-2014, 07:09 PM
vga vga is offline
Thanks I have been going crazy BC there is two measures in a song that have no midi notes recorded but the bass notes get stuck there every time. I have a Yam Es90. Im sure this is the issue. I will give it a try...
Double notes when recording w. sustain? Sandager 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-07-2007 01:09 AM
Midi Dropped Notes DreamsEnd MIDI 0 10-22-2007 08:17 PM
MIDI Dropped Notes MUSIII 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-16-2007 10:26 AM
MIDI notes being dropped guym MIDI 0 07-24-2005 06:37 AM
Move Notes and Sustain at once? NuBus MIDI 1 01-14-2003 11:06 AM
