ProTools not shutting down correctly
Hello,
I seem to be having issues with Protools Studio not allowing my Mac computer to shut down correctly. I've looked on the forums but see nothing of this issue. I quit protools and the Mac will restart instead of shutting down, at which time I can then shut down. I am not sure what is causing this. Does anyone have any ideas? I am using Protools 2023.3 with an apogee Duet 2 Mac OS Ventura / Mac Studio silicon. thank you in advance for your help and suggestions. |
Re: ProTools not shutting down correctly
If you’re trying to shutdown your computer before Pro Tools has actually quit, this may be the reason for the restart. When quitting Pro Tools make sure it hasn’t stalled by opening the Force Quit window. OPT+CMD+ESC. You’ll probably need to force quit the application. Then you can shut down the computer. |
thank you for your reply, much appreciated. I will try that.
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
thank you Stephen. I am still having the issue but it seems to be a well known issue that I am sure will be resolved in time.
There are a few well-know issues which are not disastrous but have rumbled on over decades (such as EA problems, AAE/DAE errors etc). This is not a poke at Avid type comment as these problems are common to any manufacturing of a ecosystem. The best companies reward their employees generously and develop people assets to maturity as well as their products. Stephen
excellent observation. worth repeating until it sinks in.
I have the same problem, but I found a workaround that seems to do it for me. Before I quit, I load up a very simple session and quit from there.
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB |
just a thought...
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
My issues have been PT crashing on quit, and throwing a "AAE is running out of memory" error on playback. Both seemed to come after having open large-but-not-very-large sessions for a long time, sometimes days. When you load a small session, PT/AAE clears the memory of earlier session, and I guess that fixes it. So, I'm thinking it's a memory management problem. Luckily, I haven't seen the two issues after upgrading to M2, Ventura, and PT23.3. But I haven't been pushing it much.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Problem Shutting Down ProTools LE | ecovindaloo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-30-2009 11:33 AM |
protools soundly shutting down | elad_kl | Pro Tools M-Powered (Mac) | 1 | 10-09-2008 07:10 AM |
ProTools keeps shutting down | muman | Pro Tools TDM Systems (Mac) | 5 | 07-11-2006 12:46 AM |
protools keeps shutting down | langdonfarm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-09-2005 01:12 AM |
Protools Shutting Down - Help!!!! | komodo | Pro Tools TDM Systems (Mac) | 1 | 06-06-2001 06:52 AM |
