#21
Re: Popping and Crackling - the next thread ...
Thanks for your thoughts on this!
There is no WiFi here. It's an engineering room desktop machine on cable network.
Windows 10 Pro x64 - Intel Xeon CPU E5-2630 v4 @ 2.20GHz, 2201 Mhz, 10/20 Core(s) - 64 GB Ram - ASUS Mainboard X99-E WS/USB 3.1 (LGA 2011-v3) - Most hard drives SSD - AVID Pro Tools (Native) - AVID Media Composer Ultimate - AVID Eucon artist series - RME UFX audio interface with integrated Midi interface - ADAM Audio - HEDD audio - Brauner - Klark - Scheps - Neumann - Furmann - Sennheiser ... |
#22
In the Windows Sound control panel or Sound Settings, make sure the RME is not selected as the system audio device. Pick on board or something/anything else. A good portion of USB drivers are single client meaning an app takes total control of the audio. Multi-client drivers allow more than one app to use the audio device simultaneously.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
#23
Thanks for coming back on my questions!
Ok, but isn't it a contradiction? If RME is multiclient able why should it matter? And how do you handle reference monitoring from other sources then, if they use system out but cannot be routed into the same audio out?
Windows 10 Pro x64 - Intel Xeon CPU E5-2630 v4 @ 2.20GHz, 2201 Mhz, 10/20 Core(s) - 64 GB Ram - ASUS Mainboard X99-E WS/USB 3.1 (LGA 2011-v3) - Most hard drives SSD - AVID Pro Tools (Native) - AVID Media Composer Ultimate - AVID Eucon artist series - RME UFX audio interface with integrated Midi interface - ADAM Audio - HEDD audio - Brauner - Klark - Scheps - Neumann - Furmann - Sennheiser ... Last edited by dgdsu; 05-17-2020 at 10:31 AM. |
#24
If you want to use for both, make sure bit depth and sample rate are set to the same in the Windows Sound control panel (Advanced tab) as set in your ASIO config.
#25
OP
I run Native in Win 10 with lots of Kontakt and other VIs running at 24/96 with a 64 or 128 buffer all the time - with no crackles. The ONLY way I can do this is by setting the processor affinity BEFORE Protools starts up. Here's a thread detailing: http://duc.avid.com/showthread.php?t=383052 It is also very important to set c-state switching off and disable any turbo mode switching. I run a 8700K at 4.9 GHz 24/7. My need to set processor affinity may be due to the drivers for the MOTU 1248 interface I use, but I have done many tests over the years, for me, the processor affinity switch is the ONLY way I can do low latency at 24/96 with no CPU spiking. Without the switch I get CPU spiking like crazy at low latency. Hope that helps. ejinbc |
#26
@all: Now I have less crackling up to almost zero on 128 buffer size, BUT ONLY as long as I do not enable/activate Record on one of the MIDI tracks. Then crackling goes back to hell like before. What I did until now:
But there is still massive crackling when Midi track record is enabled and there is still an absolutely unusual amount of MIDI latency going on which is NOT in par with the buffer size from my experience.
#27
Sent from my iPhone using Tapatalk |
#28
OP
Minimum buffer is a function of the driver. I really do suggest you try setting processor affinity. But, one last bit of possible help, your CPU is not really designed for this kind of work. I looked up your CPU on the PassMark site. Your SERVER class CPU has a single thread rating of a CPU 10 years old - only 1800. Probably not the best for low latency VIs. I have found that single thread rating is very important for low latency; the rating on your CPU is the same as a 2600K from 10 years ago. This may be part of the problem. Stay Safe. ejinbc |
#29
Thanks for the Processor Affinity reminder. I've had to use it - only 3 of four cores for Pro Tools - since the last couple of Windows updates have caused random crackling and pops.
#30
There is a way to have Pro Tools start with the Processor affinity you want, you just can't run Pro Tools as Administrator or Pro Tools will start, but the "fix" won't work.
Take your projects to the next level with a non-union national read at reasonable rates Demos: brucehayward dot com SonoBus Source-Connect: brucehayward Options for Remote Direction Last edited by The Weed; 06-07-2020 at 02:09 PM. |
LE 8.0.4 phantom popping, crackling. | 809578998 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-29-2011 08:33 PM |
Popping and Crackling with Digimax LT | Digitalkidd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-13-2004 08:58 PM |
Popping and crackling | sinnagod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-08-2004 07:03 PM |
Once again: popping and crackling on a AMIII | Jitter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-06-2001 04:30 PM |
Need Help! Popping and Crackling Sounds!! | Chris LoA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-07-2001 01:40 AM |
