Win 10; PT 12.5.2; Processor Affinity
Thought I would share my experiences with Win 10 - was on Win 7 with PT 12.4. Downloaded Win 10 'free' upgrade and installed it on a new SSD to get the licence established for my DAW. While the operating system was fresh I decided to test the 12.5.2 update. I also installed Waves Gold Bundle with HEQ, and NI Komplete. I use a MOTU 1248 interface - more details below.
I am pretty happy with the fresh install and everything seems to run great - the 4K monitor support is better in Win 10. However, when I record more complex sessions at low buffer (24bit/96kHz with 128 buffer) I get occasional spikes in CPU activity that cause clicks or CPU errors. I remembered a thread here at the Avid Forums where someone was adjusting the CPU affinity to reduce the number of cores used by Pro Tools. To test, I adjusted the CPU affinity so that Pro Tools only used 6 of the 8 cores in my i7 3770K. Ta Da. No more pops, the CPU spikes decreased in magnitude, and I was able to run 128 buffer at 24/96 with VIs for recording (see below for more details). After a quick Google I found a way to set affinity when Pro Tools is being loaded. Google "CPU Affinity Shortcut for a Program - Create in Windows" For my i7 system with Pro Tools, I have found that leaving 2 cores for the operating system is optimum for best real-time performance - no clicks/pops at 128 buffer. For example, the command line to start Pro Tools using only 6 of 8 cores for my install: cmd.e x e /c start "ProTools" /affinity FC "C:\Program Files\Avid\Pro Tools\Protools.exe <remove spaces in ".exe" above> I can currently run 24/96 128 buffer while recording/monitoring 12 audio channels and multiple midi-controller-triggered VIs (Kontakt Session Drummer, Piano, EPiano and Horns, and Monarch-Reaktor). With this I get about 5 ms total round trip latency with no pops/clicks or CPU errors. I will stay on Win 10 for now! My DAW PC never goes online. Cheers ejinbc >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> > Machine Details: Asus P8Z77 MB, 3770K CPU, 16 GB RAM, 512 GB SSD, 2 TB Data drive, Gigabyte 950 video card running HDMI 2.0 @ 4K resolution, all USB peripherals plugged into USB3 ports EXCEPT Motu 1248 which is plugged into rear USB2 port (no other peripherals plugged into any other USB2 channel - this was necessary to get the latency down without occasional pops in Audio with high midi traffic), Turbo Mode Off in BIOS, C-states Off in BIOS, WiFi Off in BIOS, BT Off in BIOS, On-board sound Off in BIOS, HPET Off in BIOS. Midi input controllers: Command 8, Roland TD6, Edirol PCR M80, Korg SP250, Korg Nano Software: Windows 10 (all standard DAW optimizations), Pro Tools 12.5.2 - uninstalled App Manager & Web Services, Waves Gold Bundle + Waves HEQ, Native Instruments Komplete 10, Session details for typical recording: 24 bit, 96 kHz, 12 Audio Tracks, 16 multi-channel Aux VI Tracks, 16 MIDI Tracks, 6 HEQ instances, 1 HDelay instance. |
Re: Win 10; PT 12.5.2; Processor Affinity
In your command prompt, what does the FC mean, following the word affinity? I did a Google search as you suggested, and I only came upon articles showing how to assign a single core to run a program. For example to use core 0 the command prompt would be to use affinity 1.
Do you really see any benefit from running at 96K? I have done A/B tests over the years and couldn't detect any audible difference between 48K (my normal setting) and anything higher. At 48K, and using 4 of 6 cores for RTAS processing, I sometimes can track at 128 samples, other times I have to bump it up to 256 to avoid the error message that pops up. So if this affinity command would benefit my situation I would like to know more. As you can see from my details below, I am (happily) using a very old PT version on XP, SP3.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Each CPU has a numeric value associated with it. You add up the values for the cores you want to use, then convert to hex. Decimal to Hex converter: http://www.binaryhexconverter.com/he...imal-converter Here's an example with 8 cores: Each core has a decimal value, as follows: Core 1: 1 Core 2: 2 Core 3: 4 Core 4: 8 Core 5: 16 Core 6: 32 Core 7: 64 Core 8: 128 Let's say you want to use cores 3, 4, 5, 6, 7, and 8. Add up the values: 4+8+16+32+64+128 = 252 252 in hexadecimal is FC. That's how he got that value for the command. Because he wanted to use 6 of his 8 available CPUs. |
Thanks for the explanation. I think I will try it out on my PT rig. I will use cores 3-6 for PT, so from your explanation: 4+8+16+32 = 60. From the link you gave that converts to a HEX value of 3C. I vaguely recall studying Hexadecimal values in school back in the dark ages, when they actually taught valuable subjects to students.
Sounds right to me!
Unfortunately, it didn't work for me. When I type in the command as shown above and hit enter I get the message: Invalid Switch - "\affinity". Could it be that this command is not supported in Windows XP? When I type "help" in the command promt, it lists various commands, but affinity is not one of them.
Edit: On my Windows 8 Pro computer, typing Help in the command prompt doesn't show affinity as an available choice either. I may check the command-line reference in the online help as it suggested.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. Last edited by mjslakeridge; 08-01-2016 at 10:32 AM. |
Very interesting!
I'll try it. Thanks. Enviado de meu SM-G935F usando Tapatalk |
When I did type in the command I had the correct /affinity typed in. But the response the computer gave me it was reported as I showed above. The problem I had was that the command prompt was starting at C:\Documents and Settings\Mike, rather than pointing to the directory where Pro Tools is stored. Even when correcting that, I still couldn't set the affinity using this method. After some research, it may be that the approach may work on XP Professional but not XP Home, which I have.
I set the affinity for Pro Tools manually by going into Task Manager, right clicking on Pro Tools in the Processes Tab and un-clicking 2 of the cores, and then tried to play back a session at a buffer size of 64 samples and then 128 samples and I am still getting the "The operating system held off...try increasing the HW buffer size" message. It is hit or miss with me whether I can run a session with 128 sample buffer size. Some days it works, other days not, even with the same session. CPU usage is quite low as I don't use many virtual instruments or plugins when tracking.
CPU Spikes, 12.5, and processor affinity... Work-Around? | 59.9hz | Pro Tools 12 | 12 | 07-22-2016 10:42 AM |
Dual core problems with old 6.x rig. Affinity problem. | scoobydoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-24-2007 08:12 PM |
Set processor affinity fixed -9092, -9093 issues | philwinkle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-31-2006 08:33 PM |
Dual Core Processor Affinity / 9093 9094 9129 | ikelk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-21-2006 01:31 PM |
newbie needs help---dual processor vs. single processor G4 | andtsorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 05-13-2003 05:05 PM |
