#61
Re: Sample Rate and H/W Buffer negotiation woes.
Hope MS manages to improve that with W10.
PT 12.7.1 @ OSX 10.12.1 RME Babyface Pro - MC Control V1 |
#62
I am on a Motu PCI-424 card with 1296's and now I can't get my 96k sessions to even open. Everytime I open protools it reverts to 44.1k when I change to 96k it shuts everything down and I have to start from scratch. Maddening. 2015 and no fix for this? What can we do?
#63
You can do all the required stuff, to make sure it isn't just prefs related ie trash your prefs. Make sure your aiso install is groovy. Make sure it works in other programs, ie free trial of another Daw could help narrow it down.
Daniel HDX - PT12.5.1 - HD I/O 16x8x8 Win10-Pro (v1709)- 6 Core i7-6850k - ASUS X99 Deluxe ii D-Command Main Unit - 'Ole Blue http://www.sknoteaudio.com/ plugins rock and are affordable. Last edited by YYR123; 05-01-2015 at 12:15 PM. |
#64
Try any other DAW and you'll likely say yes to most/all!
#65
Shouldn't you really have said that Pro Tools with "Core Audio seems to handle sample rate changes and asynchronous audio much more easily than ASIO and WDM" since other DAWs don't share that problem (except with Avid products)? Is that also true for Buffer size setting?
#66
You need to have ASIO4All installed and recognized by PT. First, create dummy sessions in PT for each sample rate you plan to use. No tracks, no audio, nothing at all IN the session. Save each one as "Session 44.1k", "Session 48k" etc. Then, if you're going to open a session with a different sample rate, 44.1k to 48k say, then first close out the session, but leave PT open. Switch the interface to ASIO4ALL, then open the dummy session for the new sample rate. Then switch the interface back to your interface device. Then close the dummy session open the new session. Everything should work. I"ve done this a lot and while it adds a few extra steps that take about 90 seconds, its better than having to reboot everything 3-4 times! It is also important when switching sample rates between sessions to make sure that when you close the session you also close ANY Rewire VI's instantiated like Reason or Reaper. If you don't, then things will get messed up pretty badly. Until Focusrite and any other 3rd party interface developers update their drivers to accommodate the specifics of PT, I don't know of any other way to do this.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
#67
If you think switching ASIO sample rates and buffer sizes is painful with Pro Tools, you should try switching interfaces! The attachment shows how easy all of those tasks are with Ableton Live 9 Lite (comes free with lots of Focusrite products).
P.S. Would someone please let me know whether or not they can view/download that attachment? Quote:
#68
FYI and consideration, here are some workarounds that I developed to help me and my son deal with these problems http://duc.avid.com/showthread.php?t=368422. As always feedback is encouraged (except from guitardom/mesaone). I have to ask though, why does everyone seem to think that fixing these problems is the responsibility of the interface manufacturers?
#69
Except from guitardom/mesaone?
Because you don't like being called out for spreading misinformation, huh? Maybe because it is... Ever heard of the Dunning-Kruger effect?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#70
Yes I would say you are a bit confused, in this I believe you are correct
003R+ & PT11 sample rate & buffer issue. | Nialzzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-11-2014 11:21 PM |
003R+ to PT11 sample rate & buffer issue | Nialzzz | Pro Tools 11 | 0 | 01-11-2014 12:53 AM |
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
Unable to change sample rate or buffer size with 11R | MattBaron | Eleven Rack | 5 | 03-05-2012 03:39 PM |
sample rate and buffer, help | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-08-2006 08:22 AM |
