AutoHotKeys for "Cut Time"
Hey all,
I'm desperate to create a shortcut for the "cut time" function, something I use hundreds of times every day. I've downloaded Autohotkeys but so far I haven't been able to get a script to work. Here's what I'm doing (using PT 2018.1 on Windows 10): ^u:: WinMenuSelectItem, Pro Tools, , Event, Time Operations, Cut Time... Return Any guesses as to what I'm doing wrong? |
Re: AutoHotKeys for "Cut Time"
Alt-1(number pad) brings up that window. It will always open to "change meter" the first time, so you'll have to manually select "cut time." If you hit the enter key to use the function, the window will close and you'll have to use alt-1 to reopen it each time. But if you click "apply" with the mouse, it will stay open.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
Thanks Sean, but for some reason alt+1 turns on shuffle mode for me, not the Time Ops window. Also, opening the time ops window... not much of a shortcut. I really need one keystroke for Cut Time. Any autohotkeys users out there?
it's alt+1 on the number pad. Are you using a laptop?
yes, a dell xps 13.
Ah, that's a problem. But once you do have the window open and set to "cut time," it will stay open for the duration of the session as long as you click on "apply" instead of hitting "enter." Maybe not as fast as a keyboard shortcut, but a single click ain't bad.
No, never have. I'm generally fine with the available Pro Tools key commands.
So I've been keeping open the TO window and it does save me time, yes. Thanks so much for the tip. Would still love to learn why I can't get my AutoHotKeys script to work, though.
In brief, access it via PostMessage: Code:
^u:: PostMessage, 0x111, 10271, 0, , Pro Tools Return Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" | EdgarRothermich | Pro Tools 12 | 2 | 10-04-2017 02:18 PM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
MC Mix connects correctly first time, "Network Error" after power cycle. | A Chapman | Artist Series | 4 | 07-18-2011 03:04 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
