Old 06-05-2012, 01:56 PM
thecoaster thecoaster is offline
Default Pro tools placing Samples Early. the opposite of latency.
Pro Tools 10 is placing audio early. As in, before the beat, to the left, of when it was recorded. About 2000 samples early, regardless of the H/W Buffer size.
I have tested this with a Motu Ultralite MKII, and a Native Instruments Audio Kontrol 1.
I setup a physical output/input loop (routing the Output of the interface to the Input, with a cable). Recorded the click track for two bars. It places the clicks about 1980 samples early, as in, before the beat.
This is completely unacceptable. It is a failure on the most basic level of functionality. Latency is an issue we all deal with depending on our systems, but this is clearly a problem deep within the code of the Pro Tools Software and needs to be addressed immediately.
I have a feeling that more people are having the problem, but just haven't noticed or thought it was due to bad playing.
Old 06-05-2012, 02:30 PM
Ken Black Ken Black is offline
Default Re: Pro tools placing Samples Early. the opposite of latency.
I've noticed the same thing on both the NI AK-1 and my Digi002.
Old 06-05-2012, 09:57 PM
CSJordan's Avatar
CSJordan CSJordan is offline
Pro Tools can't record something that hasn't happened yet, but it can adjust the material after-the-fact (to a certain degree). To narrow down what's making this adjustment and why, we'll have to know your full system specs and Playback Engine settings. Please see the "Help us Help You" link above and reply with all requisite information.
The most likely culprit is Delay Compensation, which heavily depends on the circumstances of your testing.
Aside from replying with your system info, try the following (in place of your initial test):
1.) Create a new, blank session
2.) Disable Delay Compensation, if enabled
3.) Create a Click Track
4.) Bus the Click Track to an Audio Track and "print" the click as an audio clip
5.) Output the printed Audio Track to a physical output and bring it back on a physical input, as you had done previously
6.) Record the loopback test to a new Audio Track
The steps above should produce two Audio Tracks of click that line up nearly sample-accurately (depending on the I/O latency specifications of your hardware interface). Let me know your findings.
Old 06-06-2012, 05:34 AM
crizdee's Avatar
crizdee crizdee is offline
You make no mention of having delay compensation on? or what level is is set at?
Or whether you have compensate for input/output delay after record pass selected in the i/o setup page?
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-08-2012, 01:57 PM
Delay compensation is not on, either in the playback engine or in the I/O.
I will do the test you prescribe, CSJordan, but i don't see the difference in doing that and recording the click straight out/in, and then testing it against the pro tools grid.
The click audio was clearly about 2000 samples in front of the grid, when i ran the output back into the input with a cable.
Old 06-08-2012, 02:08 PM
CSJordan's Avatar
The only difference is that audio is always going to occur at the same sample location. Click is triggered by MIDI Beat Clock "under-the-hood," so it's more about eliminating variables.
Old 06-08-2012, 02:26 PM
got it.
Old 06-08-2012, 05:14 PM
Shan's Avatar
Shan Shan is offline
This really needs to be a user defined value based in samples, like many other DAWs.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 07-13-2012, 04:42 AM
this is still happening.
i tried printing a click the way you described, and in that case it seemed to line up.
but now i'm just finding it happening again and again when recording audio AND MIDI. It places everything i record a little early in the timeline, about 5000 samples.
There is no doubt it. No matter what sample buffer size. I have absolutely no delay compensation enabled anywhere as far as i can tell.
Old 11-01-2012, 04:13 PM
chanman chanman is offline
I've got the same problem! Running Pro tool 10. I thought I was loosing my mind. Any fixes yet?
Pro Tools placing sound EARLY?? Zarabozo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 644 08-20-2018 06:55 AM
re-recorded tracks early by 34 samples ? john1192 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-09-2007 10:34 AM
placing in new kick and snare samples? Cmill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-02-2007 04:20 PM
Opposite of Latency? Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-16-2006 01:56 PM
701 Samples EARLY. Anti-latency 002r toddm7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-09-2004 12:06 AM
