aurora 16 errors
Hello,
I just recived my Aurora 16 hd1 bundle. I'm having a few problems. 1. the install freezes at "creative collections" giving me the error creative collections returnd an error. My second problem is I get the error "unable to locate digidesign hardware" when I start up protools. THere is a chance that the aurora LT-hd card is faulty but I'm not certain. Am I missing something? another question. Are there stero drivers for the Aurora so I can use the converter with winamp or media player All help is greatly apreciated |
Re: aurora 16 errors
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
The Aurora will work just like a Digidesign interface, and use the same drivers. So to answer your question, the Aurora should work fine for media player and winamp. Just configure it the same as you would a Digidesign interface (Control panel, sounds, change to Digidesign 1&2 for playback). I hope you get it going soon so you can enjoy recording and listening through the Aurora. I absolutely love it!!! Oh yeah, and if you're only using the one interface (Aurora) on the core card, be sure to set it up in Advanced Routing mode (32 channel mode). It will show up in the i/o of Pro Tools as 2 Digi 192's.
https://www.thirdeyerecording.com/ |
Thanks for the replys.
I visited my digi but couldn't figure out how to download Protools 8 hd.A little help please. SOmething I forgot to mention is early in the installation it says to connect the hardaware and press ok. Since the hardware is connected I press ok and continue with the installation. The Aurora is not showing up in the device manager. |
I tried to install 8.0.3 but it froze at "installing hardware"
THen I tried installing cs1 but still have the same problem. CAn't find hardware. SOmethoing I noticed is in the screen where you can select what to install there is no option to install digi drivers. This is different than LE and Mpowered that i've used Does the aroura have to be on the proper setting? If so what is it. Is it possible to install just the digi drivers? I already had to cancil a session so I really want to get this to work asap. Thanks for everyones help |
I performed a digi test. Here's what it says under slot info..."PCI card information not supported by this card"
I'm using a asus k8ndl motherboard with 2 opteron cpus. THe hd card is installed in the bottom slot. I downloaded the stand alone driver and installed it but the interface still doesn't show up in the device manager. During instalation it asks me to connect the hardare and turn on interface. Since it's connected and turned on I press ok. Also in add remove programs there are no hd drivers listed I'm having a hard time finding the multi channel driver for the Aurora. Is it available as a seperate download? If so where could I find it |
Did you buy the Aurora used? Is the LTHD card installed properly? Maybe double check, and go through the install instructions one more time. Check the jumper and check that the multi pin connector is installed properly. You might need to do a firmware update to the Aurora. The LTHD user manual gives instructions to determine and update the firmware version.
thanks so much for your help. Really apreciated.
Is it possible to download protools 8 from digi. I think my install dvd is messed up |
Another option, like Shane mentioned, might be trying to copy the contents of your DVD to your hard drive and try to install from there.
Copying as we speak.
I think I'm getting closer to figuring out what I need to do. The hd core card doesn't show up in the device manager. IS there firmare I need to install for it to? Here's what my digitest reads... under "slot info" it reads "pci card information not supported by this card" in the heading "audio i/o firmware" "displaying information for slot" it reads unknown. THe HD peripheral options are greyed out What should my "sync firmare settings be? |
many errors- fatal errors and 9060 error. Sandra report inlcuded.. | bradykrzemien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 09-16-2009 11:56 AM |
Creating DAE Objects/DAE Loaded!! errors errors HELP!!!!! | KasticK | Pro Tools M-Powered (Mac) | 2 | 10-20-2007 10:42 AM |
HW Buffer errors and Mass Confusion! 9093 Errors!! | guitarlancer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-08-2007 10:38 AM |
errors errors errors Please digi tech guys help me | dunkyj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-11-2005 01:19 PM |
Aurora Igniter - -6042 errors | schiffdigital | Pro Tools TDM Systems (Mac) | 1 | 08-24-2003 05:21 AM |
