Delay When Record/Play Button Pressed
Hey there. Thanks in advance for your help!
I am running Pro Tools LE 6.4 on Windows XP. I record through the original Mbox. I have a Intel Core2 Duo CPU, E8400 @ 3.00 GHz, and 3.25 GB RAM. The problem I am having is whenever I press the record button and then press the play button (to start recording), there is a 15-20 second freeze in the program. Once it starts recording, there are no problems. Also, when I go to playback what I recorded, there are no problems. It is only when I actually start to record. 15-20 seconds may not seem like a lot, but it adds up over time. With how much I mess up in recording, it REALLY adds up. I used to run this setup on my old computer which is 7 years older and much slower than the one I have now and I did not have a problem. Is there something I can change in my settings to get rid of this delay? The program runs smooth in every other way. Any help would be greatly appreciated. Thanks! |
Re: Delay When Record/Play Button Pressed
One quick thing to check before we get into the technical side of things;
Make sure you do not have a countoff enabled.
Countoff has been disabled.
Then you might want to see if this applies to you.
http://duc.digidesign.com/showthread...ght=play+pause
Do you have anyother programs opened? thats taking lots of cpu? or effects on?
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
You rock. This worked perfectly. There is now only about a second of delay. Thank you so much for your help! |
excellent!! make sure that if your rig has USB 1.0 that you are usin' USB2.0 ports for your Mbox. you might not have it but worth the look
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Play and record button/bar is not visible | Nomerone | Pro Tools SE and Essential (Win) | 0 | 01-16-2012 09:44 AM |
What button have i pressed?? | blackbirdstudio | Pro Tools TDM Systems (Mac) | 8 | 05-17-2010 11:06 AM |
Hitting Play or Record, blue stop button lights up... delay | Monty_python | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 09-06-2009 11:33 AM |
Anyone find the fix for the play button delay? | Parisstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-04-2005 09:14 AM |
Pro Tools LE crashing when Play button is pressed? | smattsav | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-11-2004 11:31 AM |
