Re: 9128 low CPU code
Ok thanks so it will actually say "Parked".
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
Yep, right next to the CPU # on the graph
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
I have an 8-Core i7 3820K (x79 SandyBridge-E), and still get this error now and again.
Core parking IS disabled across the board for me.
www.anvilaudio.co.uk - PC Users: Buy Skootch, you won't regret it. PC: Windows 7 64-Bit, ASRock Extreme 4 x79 Mobo, Intel Core i7-3820K @3.6Ghz, Kingston HyperX 16GB Ram, OCZ Vertex 3 64GB SSD, WD Caviar Green 2TB HDD, GeForce 560Ti GPU, SIIG TI Firewire Card, PT Keyboard. O/B: Focusrite Liquid Saffire 56, Focusrite Liquid Mix 32, Alesis D4 Drum Module, Alesis MIDIVerb4, M-Audio Axiom 49 v2, M-Audio BX8a's, Audix DP7 |
Depends on your workflow if it's a consistant problem. W7 does have near Real-Tame capabilities but the App. has got to be coded for it. PT is by far the most fragile Windows App. I've ever used. That's what ya get when you keep heaping on features for 10 years so you can make some bucks off a new version without digging in and fixing the codebase. All fixed in PT11, for sure |
Are you using Nvida GPU?? If so, is latest driver installed ??
If so, right click on your desktop enter nvidia control panel. Manage 3d settings > program settings >> Search for the PT app and turn off what you can and save settings. **I noticed everytime I close PT 10.2 and run Ccleaner registry PT creates about 7 reg-files. http://www.piriform.com/ccleaner/download/standard I fix them with Ccleaner after deleting: *DAE Pref (Program Files>Avid>ProTools>DAE) *Avid (Users>AppData>Roaming) *Database (Program Files> Avid> Pro Tools *User>AvidLogFiles (delete the file within, not the folder) Additional things I do when in PT 10.2: Go to help, check for updates and check Do Not check for updates automatically after search completes. This is unchecked everytime I launch PT. Plus I go to Options and Operation and uncheck Autobackup. Hit us back with the results. Hope this works. Peace
Win7 (32bit)/ Asus p6t Deluxe v2/ Core i7 920/ Kingston 128gb SSD/ Seagate 1tb (x3)/ Crucial Ballistix 6GB 1600mhz 8.8.8..24.1N/ EVGA Nvidia Geforce 9500 GT 1GB/ Pro Tools 10.2/ Reason 6/ Reaper 4.22/ UAD2 QUAD + UAD2 Solo (x2)/ Lynx Aurora + AES16 (pci)/ |
I'm using a GTX 560 Ti though, you'd figure it'd be up to any challenges!
*I would love to upgrade to an EVGA GeForce GT 640 but things are running smooth. So I'll bypass inserting a new gpu.
Can't really say for sure, I've just had to do a complete re-format and everything seems to be running smoothly for now, I've had a few lock-ups though.
I would try swapping for a normal 7200rpm 32mb hdd (64mb if mobo supports). The green drives have been known to cause issues. Sweetwater doesn't sell or install them in their systems for this reason.
(9128) | toolgirl | macOS | 10 | 02-20-2012 08:16 PM |
CPU Power and error code (-9128) | 456 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-03-2008 05:11 AM |
i need help with my pro tools 7le authorization code code | NDepthProductions | Pro Tools M-Powered (Win) | 6 | 03-14-2008 01:30 PM |
(-9128) Help Please | Obscene | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-03-2004 05:38 PM |
Help me (-9128)? | mtv | Digidesign Hardware & Software | 2 | 04-05-2002 03:12 AM |
