Old 10-07-2016, 11:46 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Default Custom Key Commands - broken?
Pro Tools is very limited and restricted regarding Key Commands (Keyboard Shortcuts) compared to other apps like Logic Pro X or Final Cut Pro X.
I saw posts that show that it is possible to use the OSX System Preferences to assign custom Shortcut to Pro Tools. I use that feature with other apps and it works, but not with tPro Tools
Better Touch Tool also provides such a feature, but again it doesn't work with PT 12.6.
Is that functionality removed/broken or do I miss something here?
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 10-08-2016, 01:22 AM
soybalm soybalm is offline
Default Re: Custom Key Commands - broken?
I use USB Overdrive on Sierra OS with my Logitech pc keyboard but on a MAC but I'm running 12.5.2 My main shortcut is the context key switches the edit and mix window for me. I grew to appreciate much of Pro Tools default shortcuts. It's easier to remember them.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 10-08-2016, 07:55 AM
john1192 john1192 is offline
imho, pro tools is something YOU learn .. so that everyone learns the same way .. Apple Products and other DAW's have Key Commands you can adjust .. but when the next person comes in if they do not have their own commands they are in a Quandary ... they have no idea what you have programmed ..
pretty simple ... more people need to use PT at work ... in facilities ... so everyone needs the same tools and an easy way to work ..
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-08-2016, 09:34 AM
Keyboard Maestro - works great, actively developed, very powerful.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 10-08-2016, 08:13 PM
b1daly b1daly is offline
Which menu commands are you referring to? As far as I know, they custom Mac Menu Keyboard Shortcut system is working fine. There are some commands which are not supported well under this system, (the new playlist commands, commands which have a default keyboard binding that include a number from the number pad)
Old 10-08-2016, 09:37 PM
cheers john
You think of an "either - or" situation when it comes to Key Commands, but that is not the case. You can have both worlds living next to each other. The magic word is Key Command Presets.
You can work on your machine and customize the Key Commands the strangest way. When someone comes into your studio to work on your computer, you just load the default Key Command Preset, and everything is fine.
Even in a big for rent facility. You can load the default Key Command Preset and you are familiar like any other guy, or you can bring your crazy Key Command Preset on a USB stick , load it up and be as fast as you can or used to.
Unfortunately, Avid never understood the concept that not every user works the same and won't allow any modification of the Key Commands. Maybe they have an agreement with those companies that sell those colorful keyboards with the printed Key Command labels. If everybody uses their own set, then I guess they are out of business.
Edgar Rothermich
Old 10-08-2016, 10:24 PM
I always used QuicKeys way before the OSX days, but now I'm finally give up on that company and moved most of my Key Commands to BetterTouchTools( BTT) which I used mainly for all the gestures with my trackpad. This is one of my "can't live without it" apps and it worked fine for key commands in other apps, but there is something in Pro Tools that doesn't work well.
Now, I some commands (i.e. Window ➤ Color Palette) work, but most of the others don't.
The OSX System Preferences Key Command configuration now works. The active (non-functional) BTT commands did block it.
Edgar Rothermich
Old 10-08-2016, 11:07 PM
Shan's Avatar
Shan Shan is offline
...When someone comes into your studio to work on your computer, you just load the default Key Command Preset, and everything is fine...
Exactly!...and it's not rocket science:
Unfortunately, those highly opposed with that age old justification just don't "get it"...even when the obvious solution is clearly demonstrated.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-09-2016, 07:10 AM
Benny_Cha_Cha Benny_Cha_Cha is offline
Why is BTT not working in 12.6??
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 10-09-2016, 09:32 AM
[QUOTE=john1192;2387588]imho, pro tools is something YOU learn .. so that everyone learns the same way .. Apple Products and other DAW's have Key Commands you can adjust .. You can still load the default commands and save the custom set.
Keyboard access of menu commands broken in 11 b1daly Pro Tools 11 17 04-11-2016 06:20 AM
MIDI Editor and MIDI Event Editor keyboard commands broken 12.4 HD Marsdy Pro Tools 12 5 01-31-2016 05:01 AM
Artist Color & custom wheel/ball commands? surroundsfx Artist Series 2 01-19-2012 02:40 PM
Assigning Custom Key Commands lexaudio Pro Tools TDM Systems (Mac) 7 07-13-2011 03:54 PM
