Dual Core Qualified but NOT SUPPORTED!
I think everyone here deserves an explanation on the difference between being qualified and being supported. Qualified in Digi's terms, means that the system works with PTLE. Supported means that the dual core technology is actually being utilized and code is written to take advantage of this new technology.
To this date, no PTLE software supports dual processor or dual core technology. This means you will not see any benefits with a dual core processor when using PTLE over a single core processor. I hope that Digi will be more clear in the future when releasing compatibility updates. If Digi is claiming to support dual processor or dual core technology then this is in fact false advertising. I haven't seen any claims yet from Digi other than they have qualified dual core and dual processors to work with PTLE at this time. Allen |
Re: Dual Core Qualified but NOT SUPPORTED!
allen, do you think that it's in the works in regards to the rest of the LE users out there that have multithreader P4 processors that in 7.0 that it will be "qualified" if not "supported"?
Thanks, Craig |
Yeah! you tell'em!
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
I was hoping its an early prelude to actual support in 7.0
So dont go getting that motherboard and processor quite yet is the message here.If they support dual core look out. Any other of the big sequencers supporting dual processors yet anyone? Maybe to use the digi hardware into like sonar (yuck) or something to gain the benefits?
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit |
Hello,
Cubase SX support dual cpus, hyperthreading and so dualcore cpus since SX 1.06... about five years now ! |
er1c,
Maybe it does, but you are in the PT LE forum...
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Protools is and always be my favorite.
Lol Lemix, this is "DO NOT SEE ANYTHING EXISTING ELSE" rule ? If i am in a PTLE Forum it is because i use PTLE... if not i would be in a cubase forum.
But i think digi didn't support Dual Cpus or Dual Cores in PTLE because TDM would be less interesting if native systems can run at least plungis than TDM does |
And you should see what Matt P is cookin' up with the Dual core stuff. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Well,
I just purchased a AMD Athlon 64. Digi told me that it wasn't "tested". On the initial install of Pro Tools, we did have some problems in that every time I clicked on the Pro Tools icon on the desktop, the machine would re-boot itself. It did recognize the 001 as the interface and after some re-programming of the boot.ini files (by a friend), everything seems to be running just fine. |
AMD Dual Core Optimizer and WinXP SP2 Dual Core Hotfix | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-10-2007 08:29 AM |
Dual Core Processors Qualified with LE Systems | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 29 | 08-22-2005 02:18 PM |
Dual Core Processors Qualified with LE Systems | Avid | General | 0 | 08-12-2005 12:29 PM |
Dual 1.8GHz 2nd Generation, will it be qualified? | Tanglewoodstu | Pro Tools TDM Systems (Mac) | 2 | 01-24-2005 02:30 PM |
DIGI:Why the new G5 dual 1.8 is not qualified? | ckevperry | Pro Tools TDM Systems (Mac) | 36 | 12-19-2004 08:59 PM |
