Problems with PTLE? Post your configuration he
I bought this new Dell computer, and I had PT 7.1 on my OLD computer (upgraded from 5.3.3.) But I couldn't transfer PT to this new Dell Dual Core computer, so I tried to install the original 5.3.3 disk and I get this error message:
"The application or dll C:\Program Files\Digidesign\Protools\Pace1lu1.dll is not a valid windows image. Please check this against your installation diskette." Also, after several attempts, another message comes up (when running the PT installer) telling me that drivers need to be loaded and I must re-boot and re-insert disk. This procedure goes round and round and never ends. Perhaps I need a newer version of PT? Below are my comupter's's spec's. Please help! I MISS my PT!!! Thank you! Kiki SiSoftware Sandra System Host Name : KIKI User : Kiki Workgroup : WORKGROUP Processor Model : Genuine Intel(R) CPU 2140 @ 1.60GHz Speed : 1.60GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size L2 On-board Cache : 1x 1MB ECC Synchronous, ATC, 4-way set, 64 byte line size, 2 threads sharing System Mainboard : Dell Inc. 0CU395 Bus(es) : ISA X-Bus PCI IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : AT/AT COMPATIBLE Total Memory : 2GB DDR2-SDRAM Chipset 1 Model : Dell Computer Corp RS400/200 Host Bridge Front Side Bus Speed : 4x 200MHz (800MHz data rate) Total Memory : 2GB DDR2-SDRAM Shared Memory : 512MB Memory Bus Speed : 2x 333MHz (666MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : ATI Radeon Xpress 1100 Physical Storage Devices ST3160815AS (ATA) : 149GB (C:) HP photosmart 7600 (USB) : N/A (E:) HL-DT-ST CDRW/DVD GCCH10N (ATAPI) : N/A (D:) Logical Storage Devices Hard Disk (C:) : 149GB (137GB, 92% Free Space) (NTFS) @ ST3160815AS (ATA) CD-ROM/DVD (D:) : N/A @ HL-DT-ST CDRW/DVD GCCH10N (ATAPI) Removable Drive (E:) : N/A @ HP photosmart 7600 (USB) Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Printing Support USB Controller/Hub : USB Mass Storage Device Keyboard : HID Keyboard Device Mouse : HID-compliant mouse Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Printers and Faxes Model : hp photosmart 7600 series Model : Adobe PDF Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 2) Platform Compliance : Win32 x86 Network Services Adapter : Broadcom 440x 10/100 Integrated Controller |
Re: Problems with PTLE? Post your configuration he
Do you have the installers for Pro Tools 7.1? If so, that would be the best way to go - make sure to uninstall any previous versions of Pro Tools first. |
Problems with PTLE? Post your configuration here...... | still_life_ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-30-2007 12:27 AM |
Problems with PTLE? Post your configuration here.. | DJ John | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-28-2007 10:06 AM |
Problems with PTLE? Post your configuration here.. | p3tch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-28-2007 09:46 AM |
Problems with PTLE? Post your configuration here.. | Digi ETS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1041 | 08-28-2007 09:39 AM |
Problems with PTLE? Post your configuration here.. | Gaba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-23-2007 08:01 AM |
