Old 03-18-2011, 01:09 PM
AfterJohn AfterJohn is offline
Default Focusrite Saffire Pro 24 & Pro Tools 9
So I got my Saffire Pro 24 in the mail yesterday. Sold my MBox2 Pro after I upgraded to PT9. I expected there to be some hiccups from reading about drivers, software, and general troubleshooting. This thing worked like a dream for the first 30 secs. My ext S/PDIF rack FX (Alesis Q20) lit up and my QS7 was coming through the lightpipe (there's still some clocking issues but I suspect those are QS7 problems)...
Then the Mix Control software [bleep][bleep][bleep][bleep] on me. The meters stopped moving, the GUI was froze up and no parameters wanted to change. PT was still rockin' and all the I/O was still good.
Went to Logic 9, everything's good...sweet. Back to PT...same crap, 30 secs. to 2 mins. of goodness then [bleep][bleep][bleep][bleep].
Did all the recommended troubleshooting but 1 thing...because I couldn't. Finally today when all else had failed I went to Fry's (god I love living a mile from a Fry's) and got an eSATA ExpressCard for my hard drive(s). When they say this thing likes to have the FireWire bus all to its self, they mean it. Now this thing is singing like a bird.
Obviously YMMV, but I did a lot of searching and couldn't find anything specific to my system so I'm posting this for anybody who happens to pick one of these things up and runs into trouble.
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2
redtuxedo.com
milkmoneyconsulting.com
mindexpansiontechnology.com
Old 03-18-2011, 01:40 PM
JumpingInFire JumpingInFire is offline
Default Re: Focusrite Saffire Pro 24 & Pro Tools 9
Saffire MixControl always freezes up on me with my Pro 40 whether I'm using PT9 or Logic Pro 9 unless . . . it is the only thing connected on firewire.
Old 03-18-2011, 08:40 PM
ahendy ahendy is offline
I have a Saffire Pro 24 DSP that I occasionally have some sample rate issues with. Restarting Pro Tools and correcting sample rate in MixControl usually resolves the "The current audio interface is not set to work at 48k" errors.
It's a picky FireWire device though. I had some issue with some cables, and not with others. Seems to have a problem with some longer cables. But when it works, it works great! Fantastic interface for the money.
Old 03-18-2011, 10:22 PM
I'm figuring out all the little quirks with this setup. I'm just thrilled that this combo is working solid right now. The possibilities are endless with this little thing. I'm definitely digging it.
redtuxedo.com
Old 03-19-2011, 06:48 PM
jnewry jnewry is offline
I have the same problems with the sample rate issue... It seems that I have to quit protools and start it back up any time I close a session. This doesn't help if I'm' looking for a certain session. I never had this headache with my 003... shouldn't have sold it
Old 03-19-2011, 06:56 PM
Mix Control is finicky. One thing about the MBox2 Pro...it was solid! Worked no questions asked. I was actually looking for a 003R when I came across this thing.
redtuxedo.com
Old 03-19-2011, 09:01 PM
Dism Dism is offline
MixControl + Pro Tools = a big pain in the ass.
It's too bad the RTAS MixControl plugin was not released on time... but there are betas for both Mac and Win. Allows you to make MixControl changes from within Pro Tools instead of having to restart the software.
Can be found here:
http://beta.focusrite.com/
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 02-09-2012, 02:38 AM
marko_salo marko_salo is offline
Hi!
First time poster here.
Been a PT LE 8.05 user with MBox 2 running very smoothly in my desktop 64-bit Win 7.
Have a laptop with 64-bit Win 7 too.
I'm recording my band live from Yamaha 01 -mixer through ADAT to Focusrite Saffire pro 24 dsp using Cubase Le 4 as a daw.
So far so good.
I decided to take a plunge and trial PT 10 with both of my machines figuring it would be easier to have both systems running the same daw.
Desktop installation was just a walk in the park, but laptop with Saffire 24 was as many have been complaining.
Got the sample rate issue all the time and couldn't figure out what I was doing wrong.
I changed the latency to medium (256), installed the latest mix control 2.4.1 (still a beta, right?) and the rtas-plug in (beta). The situation improved somehow, but I still got the sample rate thing going on, but not right after launching PT.
I accidentally closed the Mix Control software (after setting the sample rate to 48kHz) and then launched PT and after that I haven't been getting the sample rate -error.
Hopefully things stay this way in the future too.
By the way, can someone point me a way to good turials for PT 10 (reading or videos)?
Thanks!
Old 02-09-2012, 08:27 AM
Diccer Diccer is offline
Arrow Re: Focusrite Saffire Pro 24 & Pro Tools 9
Best thing about Focusrite is that LOOPBACK feature in the mixer that gives you virtual audio buses. This allows you to escape the matrix by running standalone programs side by side yet still sharing audio
But if MixControl doesn't work, try TotalMix. Its probably a be a more stable vmixer.
Just Run Pro Tools as a Rewire Slave/Run Parallel.. its easier than you think. Example- RME TotalMix and the IAC Midi Driver
http://duc.avid.com/showthread.php?t=313749
Old 02-09-2012, 05:32 PM
@marko_salo I'm on a Mac so I don't know if my troubleshooting will apply to you. I was getting the sample rate thing a lot at first. Once I got the Saffire by itself on the FW bus it started working right. I had to restart the whole system a few times at first, but it eventually worked itself. I also went into Audio Midi Setup and made my default I/O the Saffire and default rate 44.1 kHz.
redtuxedo.com
Pro Tools 11 and Focusrite Liquid Saffire 56 Erik318 Pro Tools 11 4 07-03-2013 06:55 AM
Focusrite Saffire 56 + Pro Tools 10 (Almost Perfect.. almost) Dot Pro Tools 10 10 06-19-2013 02:22 PM
Focusrite saffire pro 40 I/O Interface with pro tools 10 middle05macias macOS 4 01-09-2012 07:01 PM
Pro Tools 9 with focusrite liquid saffire 56 problems johanonsydow Pro Tools 9 24 02-18-2011 06:21 AM
Pro Tools 9 and Focusrite Saffire 40 how to add inputs connoyeah Pro Tools 9 2 11-16-2010 09:53 PM
