Old 01-29-2009, 07:11 AM
crizdee's Avatar
crizdee crizdee is offline
Default Trying to make keyboard shortcut for insert/sends F-J works for edit window only!
I have used the keyboards shortcut utility in the mac system prefs/keyboard and mouse to create various key commands, but for some reason the 2 i have created for opening and closing inserts and sends F-J will only work in the edit window and its the mix window thats getting too convoluted to view everything!!
Anyone find a way to get key shortcuts for opening and closing said functions
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-29-2009, 10:26 AM
EvilElfBoy EvilElfBoy is offline
Default Re: Trying to make keyboard shortcut for insert/sends F-J works for edit window only!
I have done it with quickkeys, it's pretty easy to do because views are in a menu. Did you want me to send you a vid on how to do it?
AKA - EvilElfHobo
Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4
Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified.
Multi-Platinum Pro Tools Videos
Old 01-29-2009, 11:28 AM
Shan's Avatar
Shan Shan is offline
Originally Posted by crizdee View Post
On PC I'm able to select these views individually. It sounds like the unique ID command numbers got changed. There should be separate command ID numbers on the Mac for the Mix Window. I noticed on PC that some of the command numbers in the main menu on PC got changed, which may also be the case for Mac so have a look in that area.
Hope that helps.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 01-29-2009, 11:55 AM
I think you are right Shane, I know i had to redo a bunch of my quickeys to work proper after the upgrade.
AKA - EvilElfHobo
Old 01-30-2009, 04:30 PM
crizdee's Avatar
Thanks for the offer! unfortunately i don't use quickeys.
i'm still a bit confused why it works on thee edit page and not the mix window! and surprised the Digi didn't write a shortcut for this
Chris
Producer, Engineer,
www.ukmastering.com
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
Meters in sends in EDIT Window are not coming up propower macOS 3 11-08-2012 10:28 AM
Another Keyboard Shortcut question - I/O and Inserts/Sends stpete111 Pro Tools 10 4 05-02-2012 08:45 PM
keyboard shortcut for opening an insert n8tron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-14-2007 09:00 AM
Can I have different sends showing for each track in the edit window? sevan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-08-2001 05:44 AM
