#21
Re: Haswell build
The Dverb test was never meant to be "real world". It's a benchmark stress test used to measure and compare systems with and nothing more. It's like using a tape measure. It's primary use has been to see if a new build was put together and optimized properly. If we're all building the same computer and getting the same results, but a new system scores significantly lower, then we know something is way off with that build which we can now investigate. It's also used to measure different releases and versions of Pro Tools. If there's a substantial hit in a new release, then something is way off with PT and we can notify Avid. We also use it to measure and compare CPU types.
The problem with a so called "real world" test is the definition of real world itself. An individuals real world session either runs or it doesn't. Once one does a Dverb(or DaveC) test, they now have a base with which to compare their own real world sessions with. The best real world tests that we have already are the gradient DaveC tests. No sense reinventing the wheel unless someone feels the need to go from Imperial(Dverb & DaveC) to Metric. After I do my own builds I run a Dverb benchmark to make sure everything is running smooth and it's all in the ballpark. I then come back to the forum and brag how my system is more powerful than yours and half the price. After that, I just get on with recording my real world stuff. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#22
Re: Haswell build
Benchmark the ten dverb's - b/c the prior benchmark seems a bit too low for future computers
#23
Re: Haswell build
The current gen. of Haswell is heat limited on overclocking anyway. I bought the 5H to get certain features. Gigabyte has a Thunderbolt version of the 5H out now, depending on your interface might be worth the extra bucks.
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra |
#24
Re: Haswell build
I'll post my DVERB scores as soon as the liquid nitrogen tanks get here
Scores like this only make sense comparing the exact same system, running the exact same software, in the exact same configuration with the exact same interface. Even for optimizing your own system you want a session that is real world for the way you work. No you can't get any bragging rights, but you can get back to work.
#25
Re: Haswell build
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#26
Re: Haswell build
OK, thanks.
I wonder how the Haswell Mac's are playing?
#27
Re: Haswell build
Here's my Haswell build (also in the i7 Thread):
Case: Silverstone Fortress FT02B-USB3.0 Power Supply: Corsair RM Series RM850 ATX12 v2.31 Motherboard: ASUS Z87 PRO Socket 1150 CPU: i7 4770K Quad Core Socket 1150 RAM: G.SKILL Trident X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) CL: 7 Model F3-1600C7D-16GTX CPU Cooler: Noctua NH NH-D14 Video Card: Asus GT640-DCSL-2GD3 GT 640 2 GB GDDR3 SDRAM - PCI-Express 3.0 x16 Fanless Video Card Model: GT640-DCSL-2GD3 Firewire Card: SIIG FireWire 2-Port PCIe (NN-E20012-S2) OS and Audio Drives: 2 x 500 gb WD Caviar Black SATA 6 gb/s 7200 RPM 64 mb cache drives Backup Drive: 1 x 1 tb WD Caviar Black SATA 6 g/s 7200 RPM 64 mb cache Firewire Card: SIIG FireWire 2-Port PCIe (NN-E20012-S2) Software: Pro Tools 11.1.1 on Windows 8.1 Pro Interface: 002 Rack All Avid Windows 8 optimizations done (except Network Card Enabled) and BIOS optimizations done too DPC Latency Checker: 7 to 13 ups for the most part with a regular spike to 997. DPCLC states the computer should be able to handle real-time audio and video streams LatencyMon: Svchost.exe causes hard page faults, but LM states the computer should be able to handle real-time audio and video streams Core Parking OFF: All CPUs report 100% in Task Manager DVerb2 Score: 65 Tracks/325 DVerbs with Both Dynamic Plug-in Processing and Delay Compensation On and my Network Card Enabled (didn’t make any difference if it was Enabled or Disabled); Hyperthreading is On System Monitor: Memory at 12%; Disk Usage 23 to 30%; Total 90 to 99%; Cores 1 through 8 running 85% to over 90% Third Party Plug-ins: Waves Diamond Bundle v9r14, Blue Cat Free Bundle, Melodyne Single Track - just realized the DVerb2 test is supposed to be done with the Stock plug-ins only. I'll try to get some time to do the test with the third party plug-ins in the Unused Plug-ins Folder Backup Software: Acronis True Image Home 2014 Monitor: Dell 29” Ultrasharp Can always drop in the 8 core Haswell later. Cheers,
#28
Re: Haswell build
Nice Build.
I measured my DPC with PT running and my boot up DPC is similar to yours, but I have no spikes. My ASUS board had a Marvell disk controller that threw big spikes, you might try disabling yours if it has one.
#29
Re: Haswell build
Dave,
Thanks. The spike is still in the green - just. I'm thinking it may be my KVM switch polling the USB connection. Whatever it may be, it hasn't been a problem with any sessions, including those with a video track. If it does become a problem, I'll go looking for the Marvell controller. Cheers,
#30
Re: Haswell build
New Imacs Out Today (Haswell) | nst7 | macOS | 2 | 09-24-2013 07:38 AM |
Any Haswell builds? | dave911 | Windows | 3 | 09-13-2013 08:42 PM |
DPC Latency in Haswell | dave911 | General Discussion | 8 | 07-17-2013 08:08 PM |
Haswell technical question for Avid | darbyclash34 | Pro Tools 11 | 11 | 06-03-2013 04:01 AM |
Haswell Processor - TSX or not | dave911 | General Discussion | 2 | 04-24-2013 05:19 AM |
