  #81
Old 01-08-2011, 11:00 PM
DJ Hellfire DJ Hellfire is offline
Default Re: W7 x64 optimzations for 8.0.4...
Originally Posted by audiogeekzine View Post
video doesn't fit on my screen.
Before you press play, press CTRL + (-) to zoom out!
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
  #82
Old 01-08-2011, 11:26 PM
Originally Posted by Shan View Post
Here is a small utility app I developed that will speed up the menu delays in Pro Tools, and the rest of the Windows 7 UI. The menu delay is the amount of time it takes for a menu to fade, pop or slide open when the mouse hovers over it:
PT Menu Delay Utility
Shane
Can you re-up this tweak? Can't download! Thanks!
Pro Tools 2021.12
  #83
Old 06-23-2011, 11:23 PM
Shan's Avatar
Shan Shan is offline
New download link:
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
  #84
Old 08-06-2011, 09:51 PM
dstryrwiz dstryrwiz is offline
New download link:
Shane
The link doesn't work anymore. Can you reupload? Thank you.
  #85
Old 09-03-2011, 02:46 PM
jonnn's Avatar
jonnn jonnn is offline
Originally Posted by mykhal c View Post
here are some optimizations i made awhile back. you can check 'em out and see what helps and what doesn't...
http://www.screencast.com/t/MjAzMTIwN2Yt
http://www.screencast.com/t/ZTk4NTQ2YjYt
http://www.screencast.com/t/ZTllODNmN watch out for the internet/online tweaks in this one. FYI...tweaks are for PTLE partition...online access disabled
http://www.screencast.com/t/MjIxZmUwYz
http://www.screencast.com/t/YjYxNzRhMzMt
alternate download links... (links usage gets reset the 15th of every month)
http://www.screencast.com/t/OTc1YjY1
http://www.screencast.com/t/NzI3NGRkNWYt
http://www.screencast.com/t/N2Y4YjJmMWE
http://www.screencast.com/t/ZDM3NzMwNDQt
http://www.screencast.com/t/NzIyMjQ0NWIt
here is one that is not included on the swfs...
to get rid of hiberfil.sys which will continue to grow as system usage continues.
1) go to command prompt usin’ run as admin
2) type ‘powercfg.exe /h off’
3) reboot…file is now deleted
this file will get huge if you leave it active…
IIRC with these tweaks my OS loads up usin' 680mb of ram...down from the +1gb that it usually loads up with. hope these help...
Hi mykhal, thanks for the tweaks. But I couldn't get the last two to play. Tried both links in firefox and ie and I get nothing but a white screen. If you get a chance to look into it, I'd love to do whatever's in those two vids.
Thanks!!!
Jon Lesher
Mixing Engineer
Editor
jonlesher.com
thedrumeditor.com
Studio pre-production guide
Drum recording guide
  #86
Old 02-20-2012, 09:36 AM
spenner spenner is offline
A thousand thanks to this thread. On the i7 930, W7 Pro x64 bit used 1.5-1.7 G's RAM on startup. After the tweaks it's now in the 800s.
Question: On the Core 2 Quad, Intel DP45SG Mobo, a HDD recently failed. S.M.A.R.T. is enabled but I got no warning. My HDD's are constantly backed up so if one fails I replace it and restore files with Acronis. Is it OK to disable S.M.A.R.T.
Also, what about XD Technology and SpeedStep Technology?
