#21
Re: Can I get 64 track max with PT8 & MPT 1.?
ok...on the /3gb switch. the key is DO NOT use the /userva switch to limit the apps. that and make sure you have your paging file set to 1024 for that extra gig of memory (even tho it's virtual). here's a link to the switches available... http://support.microsoft.com/kb/833721 valuable text from link... /3GB This switch forces x86-based systems to allocate 3 GB of virtual address space to programs and 1 GB to the kernel and to executive components. A program must be designed to take advantage of the additional memory address space. With this switch, user mode programs can access 3 GB of memory instead of the usual 2 GB that Windows allocates to user mode programs. The switch moves the starting point of kernel memory to 3 GB. Some configurations of Microsoft Exchange Server 2003 and Microsoft Windows Server 2003 may require this switch. /userva Use this switch to customize the amount of memory that is allocated to processes when you use the /3GB switch. This switch permits more page table entry (PTE) kernel memory but still maintains almost 3 GB of process memory space. Note Microsoft Product Support Services strongly recommends using a range of memory for the /USERVA switch that lies within the range of 2900-3030. This range is wide enough to provide a large enough pool of system page table entries for all currently observed issues. Usually a setting of /userva=2900 will provide close to the maximum available number of system page table entries possible. and as we all know, thanks to you and sunburst, the video cards do come into play. one more link...http://blogs.technet.com/askperf/arc...fying-3gb.aspx for those that really wanna dig into it!!! i've got more techie links but i gotta dig 'em up. and i've already proven that my 'search for $.h.i.t' finger is not really participatin' today!!!! thanks Shane!! you da man!! EDIT: oh yeah...what's the syntax for applyin' unique names to URLs??? i said i'm lazy today!!!
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#22
one more link... ...and great post!! It will get lost and I'll ask you about this again(along with everyone else) so bookmark it to link to. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#23
Bob you crack me up. I think I now have 4 smacks!! LOL
"It aint about the stuff you got..If it sounds right you're finished..Burn it!" For all complaints click here DAW-Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent |
#24
#25
Your post on the 3G switch was killer...but where's the HD tutorial vid? We need our hands held in here! Shane
#26
#27
I hope i dont have to get my own server going. Shane
#28
so...
this gets you 3.0 GB RAM to use in Pro Tools vs the old thread which gives you 2.7?
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
#29
#30
I feel like I'm missing the instructions somewhere.
My Boot.ini looks like this: [boot loader] timeout=3 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /fastdetect /noexecute=optin multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional 3GB" /fastdetect /noexecute=optin /3GB What should it be?
Copy Audio Track Automation to Midi track controller (Mod Wheel) | cybercampbell | macOS | 3 | 05-11-2013 10:18 AM |
Track show/hide markers disable track record status | BigBangPost | Post - Surround - Video | 4 | 03-27-2013 08:03 PM |
Unable to Record (digitize) a Regular Midi Track to an Audio Track | JuicyMusic | macOS | 9 | 02-27-2013 08:52 AM |
Bounces selected track but shows remaining time of longest track | mwsmith007 | Tips & Tricks | 5 | 01-06-2013 07:21 AM |
PTLE 8 midi track controls inst track levels? AND much more. | geetar777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-25-2010 05:41 AM |
