Old 01-27-2011, 11:14 AM
gerarddaly gerarddaly is offline
Default Protools 9 - Unable to Locate Hardware
Hi, I just bought Protools 9 (LE Crossgrade) today, I registered the software to my account, registered the iLok, and installed the software on my Windows 7 (64 bit) PC - everything installed fine...but just as Protools 9 was about to open, I got a message "Unable to locate hardware, make sure your hardware is connected and then click 'ok' "? So basically Protools 9 is asking me for Avid/Dididesign hardware again (even with version 9)?
I was the owner of an Mbox 2 mini, but I just sold it a few days ago to someone who didnt need the licence, so that way l could keep my Protools 8 licence and buy the crossgrade.
The main reason I bought Protools 9, was that I read in all the music technology magazines said that you can use it with any audio interface...and I just wanted to use it with the soundcard inside my PC. My internal soundcard is installed and working in device manager.
I have just spent a lot of money on this software, but now I cant even use it...I thought that when installing Protools- it only asked you for Avid/Digidesign hardware in versions 8, and not version 9 also?
Can anyone help?
Old 01-27-2011, 12:14 PM
Default Protools 9 Unable to Locate Hardware
Can anyone help?
Old 01-27-2011, 12:20 PM
DigiTechSupt's Avatar
Default Re: Protools 9 - Unable to Locate Hardware
Most likely the built in sound card does not have an ASIO driver - you may want to check to see if it does and, if so, install it.
If it doesn't, you could try installing ASIO4ALL.
Avid Audio Tech Support
Support FAQ
Old 01-27-2011, 12:21 PM
Park Seward's Avatar
Park Seward Park Seward is offline
http://tippach.business.t-online.de/asio4all/
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-27-2011, 12:26 PM
Default PT 9 - LE Crossgrade
Hi, has anyone with LE Crossgrade been able to install PT9 on Windows WITHOUT there old Avid/Digideisgn connected?
I keep getting the following message: "Unable to locate hardware, make sure your hardware is connected, and then click ok'".
I thought you didnt need any old Digideisgn/Avid hardware connected once you had PT 9 and an ilok?
Old 01-27-2011, 12:29 PM
Dism Dism is offline
Default Re: PT 9 - LE Crossgrade
http://duc.avid.com/showthread.php?t=293229
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Avid says to only post your question once. It has been answered.
Park
Old 01-27-2011, 12:34 PM
Hi, has anyone with LE Crossgrade been able to install PT9 on Windows 7 (64 bit) WITHOUT there old Avid/Digideisgn connected?
Old 01-27-2011, 12:35 PM
Dude... seriously... read one of the half dozen other threads you started...
D
Old 01-29-2011, 10:41 AM
ASIO4ALL worked- thanks a lot guys...
ProTools LE 10.3.4: Unable to locate hardware elcabong Windows 3 06-21-2013 08:44 AM
"Unable to locate digidesign hardware" Mbox (original) ProTools LE 7.4.2 Mac OS X sharpd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 04-27-2012 12:11 AM
ProTools was working but it is now "Unable to locate Digidesign hardware" muso90 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-11-2011 02:59 PM
mbox 3 protools 8... UNABLE TO LOCATE DIGIDESIGN HARDWARE!!! eyensteyn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-28-2011 05:07 PM
ProTools unable to locate hardware. agentorange29 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-19-2008 08:08 PM
