**STILL** Bad record/playback bug in 6.1???
I don't know if any of you have seen this before and may have some remedy...but I upgraded to 6.1 last week, did my first session with some clients this weekend, and had this problem. Probably 4 times out of 10, when I would hit F12 or "record-play" on the transport window, the cursor would back up the allotted 5 seconds of preroll, then just stop. No record. No playback. No nothing.
I would then have to again place the cursor where I needed to record and hit F12 again and hope for better results. This wasn't a big deal when we were doing initial tracking, but gets unbelievably annoying when cutting bits of vocal takes and having to replace the cursor and re-tell the computer to record almost half the times I need it to record. Has anyone seen this before or have an idea of what could be done to stop it? I really need some help here. |
Re: Bad record/playback bug in 6.1???
Has no one seen this? It's really annoying. Please help.
What setting do youi have in your prefs for "Open Ended Record Allocation"? Try 10 minutes and see if it helps.
Rail
Where is that setting located? I can't seem to find it.
Hello,
-Open the Setups Menu go to Preferences > Operations tab and limit the Open Ended Record Allocation to 10 minutes. Mike |
In the Setups menu->Preferences... On the "Operation" tab last item on the right.
Rail
I have similar probs. I have to hit 'play' or 'record' 2 or 3 times before it will start. When I observe the transport the 'stop' button very quickly turns blue before the 'play' button. But it does this randomly. The lower the buffer setting the more often the prob occurs. Seen this on 3 different systems. Turning off page filing and increasing the buffer size will help but I didnt need to do this in 5.3. I have an earlier post regarding this called 'playback problem' somewhere.
right click 'my computer'-properties-advanced-performance-settings-advanced-virtual memory-change-select 'no paging file' then 'set' for both drives. This in combination with increasing the buffer size has solved it for me but what a pain. Shan
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
i'm still having problems with this. now instead of it happening 2 out of 3 times, it's just 1 out of 3. verrry annoying.
Pedrohead,
I have a feeling this is NOT your problem, but I thought I would throw it out just in case: here is a bug I've found that involves F12. If you click in one of the preroll or postroll time sections in the transport window and change the setting and then hit enter (to 'set' it), you can't use F12. As a matter of fact, if you just click in one of those sections and then try and use F12, it won't work. To make it work you have to click somewhere in the timeline on the main window (so that focus shifts to the main window). Anyway, if this is not your problem, just add it to the bug list (I know this did not happen in 5.3.1). |
Actually, I have noticed that, too. But I have this problem even when I use the transport bar. I've tried the fixes that DIGI and the other kind gentleman suggested, but it just lessens the occurances, not eliminates it.
Can't Record and Playback? | iFengo | Pro Tools 10 | 2 | 12-12-2012 12:37 AM |
How do I set Ext. HD to Playback or Record? | jeffbrooks | Storage Subsystems | 4 | 01-04-2011 09:12 AM |
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts | The Muphin Man | Pro Tools SE and Essential (Win) | 8 | 09-10-2010 07:03 PM |
record (playback only 256 up ) why 128 no record | sayed mohammed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 05-02-2009 07:17 PM |
Playback, Record and the .wav | rthomas | Digidesign Hardware & Software | 2 | 09-05-2001 04:40 AM |
