Installing P.T. 10 on iMac using vm fusion 7?
I’m using a:
Model Name: iMac Model Identifier: iMac14,3 OS X Yosemite Version 10.10.4 Processor Name: Intel Core i5 Processor Speed: 2.9 GHz Number of Processors: 1 Total Number of Cores: 4 L2 Cache (per Core): 256 KB L3 Cache: 6 MB Memory: 16 GB Boot ROM Version: IM143.0118.B11 SMC Version (system): 2.17f7 I’m unable to install Pro Tools 10 on OS X Yosemite, but have installed Pro Tools 11 I’m wondering if this work around will work and asking if anyone has had any experience in installing VM Fusion 7 on a iMac, then installing Windows 7, then installing Protools 10 & 11 onto the Windows 7 platform residing on the OS X Yosemite? |
Re: Installing P.T. 10 /11 on iMac using vm fusion 7?
There is an officially unofficial way to install Pro Tools v10.x on OS X Yosemite, though you WILL experience issues that Avid is not going to fix.
Re: Installing P.T. 10 on iMac using vm fusion 7?
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
You're right about not going the vm route, especially given that the op's machine is only an i5 cpu. |
The ability to downgrade the OS would be dependent upon when this particular iMac started shipping and which OS was the current release on that date.
But as far as the iTrashcan goes hardware changes don't enter into it; I believe it's a firmware change that could be the deal-breaker in taking a Yosemite machine backwards in OSX versions. |
friend has an IMac i7 with fusion drive, is he SOL? | wwittman | Pro Tools 12 | 35 | 05-06-2016 12:35 AM |
Am I screwed? iMac Retina i5 with a Fusion Drive | danjlambert | Pro Tools 11 | 7 | 06-28-2015 02:35 PM |
PT11 with iMac (Late 2012) and Fusion Drive | Rohrak | Pro Tools 11 | 7 | 03-31-2014 06:32 PM |
MBox Pro 2 Cuts Out on New iMac (Fusion Drive) | aswink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-30-2013 04:36 PM |
