Bounce to disk error message - Please Help!!!
I recently had a problem with this error message:
“\code\aztec_Staley\AlturaPorts\NewFileLibs\Ff\Aud io\FF_Audline 33. So I searched the fourm looking for answers and I came accross a thread that was identical to my problem. In that thread there was a link that explained what to do if the problem occurs. I folled the instructions throughly and now I am having a problem with my Plugins not working, but they are all installed still. Please help, I am not sure if this a simple fix or if I need to reinstall all my plugins again. The link: http://www.sweetwater.com/expert-cen.../d--06/09/2006 |
Re: Plugin Inactive Problem
It looks like those tips came from this sticky.
We'll need some more details of your rig. Computer build, PT version and hardware etc. Thanks. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
I am running: ProTools V7.0, MBox2, Windows XP Pro. Playback Buffer and CPU Set to max.
Manufacturer: INTEL_ Processor: Intel(R) Pentium(R) 4 CPU 3.20GHz (2 CPUs) Memory: 3324MB RAM Hard Drive: 405 GB Total Video Card: RADEON X850 Series Monitor: ViewSonic VX924 Sound Card: SB X-Fi Audio [1000] Speakers/Headphones: Logitech Keyboard: USB Root Hub Mouse: USB Root Hub Mouse Surface: Flat Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254) I reinstalled all of the plugins and they now work again, but that error I was getting is still comming up. I tried several times and each bounce is 60 mins. Any suggestions. I am running my system with the HT on. Does that matter? Do I gain performance if I disable it, or do I gain stability? Thank You for you assistance. |
Re: Bounce to disk error message - Please Help!!!
Also, try a 5 minute bounce and ten minute bounce to trouble shoot. When you do this, change your Open Ended Record Allocation to 10 minutes and report back. What are you bouncing that is 60 minutes and what plug-ins are you using during the process? Shane
Shan
Is that a sound blaster card he is using,if it is Ill say no more Good luck Brandy |
It is a top of the line Sound Blaster sound card that I spent some good money on. I though it would help me with my sound processing. I don't have any problems with it, that I know of. Is it better to use my onboard audio drivers?
The track I was bouncing was only 2 mono tracks and T-Racks EQ on each of them. That's all. I will try the tests and I will post my results. Thank You for your help. |
I managed to get a few lucky bounces using the hard disk allocation trick. But it happened again. I bounced 2 tracks that were about 60 mins so I put it to 65 mins to be safe. Then I had problems twice doing a 40 min bounce. Got the same error.
Should I try to back up the Hard Drive and format it and try again? I think I might be having an issue with paging file allocation according to my Disk Keeper software(Defragmenting)for that drive. Would that affect that because it states that performance is affected if you do not allocate more paging file space? I don't know about that stuff, your expertise is greatly appreciated. Thank You, Goodshotz |
Crazy error message on bounce to disk | howie b | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-20-2009 01:51 PM |
bounce to disk bizarre error message and frustrati | andycopeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-25-2005 08:44 PM |
Bounce to Disk using mp3 - Error Message | Brian Forrester | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-01-2005 06:35 PM |
Bounce To Disk Error Message | John Pisciotta | Pro Tools TDM Systems (Mac) | 1 | 05-17-2005 02:53 PM |
Bounce to disk Error Message: Help! | SteveU | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-20-2004 08:50 AM |
