  #21
Old 05-19-2014, 09:52 AM
Larold Larold is offline
Default Re: Track Input Monitoring 10.3.9 HD broken ?
Input switching problem here too. If I hit stop, it seems to reset itself, until I have to monitor input again. Makes the software unusable. I cannot work with this.
  #22
Old 05-19-2014, 08:53 PM
WernerF WernerF is offline
Avid?!! Any comment on this absolutely ridiculous situation? It, quite obviously, makes this update completely unusable. That is NOT acceptable.
  #23
Old 05-20-2014, 06:30 AM
I know that there are moderators here but is anyone from Avid checking these forums anymore? Is the fact that this issue exists at least being passed up to the Avid guys by the moderators. Can someone please chime in on this. Thanks in advance for any kind of answer.
  #24
Old 05-20-2014, 08:37 AM
Synchrosphere Synchrosphere is offline
I think avid apparently has no interest to comment on this bug. buy kindly Protools 11 annoying customer!
  #25
Old 05-20-2014, 08:55 AM
Stig Eliassen's Avatar
I have reported this a while back, and I will try to raise some attention to this again. It is, like you said, not acceptable at all.
  #26
Old 05-20-2014, 10:58 AM
Thanks Stig. Hopefully they are putting some effort into it.
  #27
Old 05-20-2014, 02:11 PM
ChrisSimon ChrisSimon is offline
+1
Does anybody know, how to downgrade to 10.3.8...
I uninstalled 10.3.9, installed again the full installer of 10.3.8, restarted computer, started PT and got just a very short Flash of the Logo and nothing more...
Prefs etc were deleted before..
Best
Chris
Chris Simon
www.TwinMusic.de
  #28
Old 05-20-2014, 03:51 PM
hivestudios hivestudios is offline
Input monitoring is indeed broken in 10.3.9 Sometimes it works, usually it doesn't. It's most flakey when the input of the track you're trying to record to is set to a bus. So it's a real pain when you're trying to bounce down some processed tracks.
I'm using Mavericks, but as soon as I managed to downgrade to 10.3.8, it worked flawlessly, so clearly something broke between the two versions.
I also had the error of the Pro Tools logo just flashing for a second before disappearing after trying to uninstall 10.3.9 and then install 10.3.8. So I followed these instructions very carefully (they're halfway down the page):
http://duc.avid.com/showthread.php?t=350337
You should note that in order to delete some of these files, you have to "show hidden files":
http://ianlunn.co.uk/articles/quickl...s-x-mavericks/
Also, in the instructions above, there is a small error:
com.digidesign.ProTools.plist
DigiSetup.OSX
Pro Tools Prefs
Are in ~/username/Library/Preferences, NOT ~/Library/Preferences
  #29
Old 05-20-2014, 07:43 PM
Chief Technician Chief Technician is offline
Question Re: Track Input Monitoring 10.3.9 HD broken ?
Did you select the Clean Uninstall option?
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
  #30
Old 05-21-2014, 01:48 AM
DigiSetup.OSX
Pro Tools Prefs
the same on my system
Track Input monitoring!? realizment macOS 9 11-04-2013 01:51 AM
Monitoring input and track during playback simonyeah Post - Surround - Video 5 09-24-2012 03:07 PM
track input monitoring vin7 Pro Tools 10 6 08-28-2012 07:08 PM
Pro Tools Track Input Monitoring??? MLH Studios Inc. Pro Tools 10 13 03-13-2012 11:03 PM
Single track Input Monitoring?? sylviesongs macOS 1 09-19-2011 01:41 PM
