notepad in pro tools???
Hello,
I was just thinking as I was working in Pro Tools...it would be cool if there was a notepad where you could write down ideas or settings from your session somewhere within the program, and it would save the information within that session so each time you came back to the sesh, you could find your old settings or ideas if you needed too. Is there something like this in Pro Tools and i just don't know about it? chal7ds |
Re: notepad in pro tools???
File > Get Info
This command lets you enter and save information about the session. Left-column text fields are topic fields. Text entered there is saved with your Pro Tools Preferences and will appear in all sessions, allowing you to preset the field to topics that you commonly use. Right-column text fields are information fields and are session specific and will be saved with the session. Also, each track has a Track Comments View. I usually include a .txt file within the session folder with any additional info including digital pics of outboard gear settings and .pdf's of any recall sheets. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
oh cool! i like this...the one thing that sucks is it only lets you type in so much info before it stops..i was expecting the field to open up once i got to the end so i could fit more text! blah. maybe PT will update this on the next version..
thanks dude.. chal7ds |
You can use notpad at the same time as PT using the ALT/Tab feature to go between the two. PT will not quit working while you use it either. I use it all the time, and just save the .txt files to the session folder. Works awesome.
Sign up for all things....AWESOME! Kris May the music move you |
The COMMENTS box with each channel strip is also handy for notes.
Another thing you can do is save all your plugin settings for the session in the session folder. Make sure you come up with a naming system which works for you. This makes different settings easy to compare and they remain with the session.
gonzo HANSON'S RAZOR: Never attribute to evil that which can be adequately explained by stupidity. |
Thanks Shan, that was good stuff.
In some instances, I like to use Memory Locations: just put the Edit Selection wherever you want it, then open a Memory Location (shortcut is Enter on the Numeric Keypad in Windows) and post stuff in the Comments area. Too many of these could get messy, I suppose; just depends on how you're using them. For example, I just used one where I went to the beginning of a drum clip and recorded the idea that "Vocals follow the kick drum." |
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
So this just inserts like a normal plug and stays in the session? Sent from my iPhone using Tapatalk |
Funny "focus" error in Pro Tools - Notepad | AlexLakis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 04-02-2010 10:10 AM |
lyric notepad in pro tools | n8tron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 03-12-2010 11:46 AM |
Finale Notepad - off topic | Bunting Ho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-30-2002 11:27 PM |
How about a notepad within PT | Mano | General Discussion | 7 | 07-14-2001 02:16 AM |
