Anyone get Pro-Tools 8 To Work Without Issue On A P5K Quad Build?
I'm this close to doing a clean installation of Windows SP3, and PT8 and actually following the setup guidlines. PT8 is working excellently, but the autosave crapout problem is killing me, and I think its time I get rid of the AV and stuff on my system anyway.
I'm just curious to know if anyone with a similar build to mine has got this going.
Macbook Pro 15" (Mid 2014) 16GB RAM 512GB SSD Pro-Tools 12 2.5GHz i7 Quad Core |
Re: Anyone get Pro-Tools 8 To Work Without Issue On A P5K Quad Build?
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
I'm using the Asus P5K3 Delux with Wifi, a Q6700 and DDR3. But disabled the Wifi cause no internet for me on my DAW.
Have no problems here with PT 8, even autosave is working. Have to say that I'm using the M-Powered version. |
Q6600, WinXP SP3, 4GB RAM (nothing fancy), and a P5K mainboard that is so plain I was afraid that it would get confused with anything past 2+2..
Occasionally I have the start/pause thing crop up, and twice in two weeks I have had the autosave error say hello.. but mostly worry-free.. and certainly powerful. I do know that when my WIFI is enabled the pause/start thing is almost constant. Hope this helps.. Peace!
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
I've got the P5K, Q6600 OC'd at 3GHz, 4GB RAM. I am running PT8 and haven't noticed any problems.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4 |
I plan on reinstalling PTLE 8 on a clean Windows installation.
So out of curiosity . . Are you all ignoring all of the updates which you could download (since SP3s release) for Windows? Are you all, authorizing your Virtual Instruments by telephone or using another PC? I think I might like to shut the internet out completely from this rebuild. Do you guys install the MOTHERBOARD MONITORING PROGRAMS that usually come with your boards to watch CPU Temp, etc???
Installing PT8 after a clean windows installation is always good.
Never upgraded my OS it's SP2 and it works fine so no need for upgrading when it's all working. Disabled my network cards so no internet on my DAW. To authorize I'm using another PC. It’s always good to monitor your temp’s, but need to know your PC as well. I haven't installed the monitoring software for my temp's. If you're know what you're doing you can do a CPU stress test and some other benchmark tests like I did, to know what your PC can handle. I monitored my temps and some other things by using HWMonitor and CPU-Z by cpuid.com. You can also do the The Dverb Test you'll find it here on DUC and monitor your PC. So you know what your PC can handle. |
I have my system up and running great. Although I am not using windows as my OS.
Pro Tools 8 LE Digi 003 rack ASUS P5K DELUXE Intel Core 2 Quad 2.4 GHz Q6600 8GB DDR2 SDRAM DDR2 800 Video GeForce 8600 GT ASUS DRW-20B1LT SATA DVD WD 320GB SATA internal drive OWC external 500GB firewire drive OS 10.5.6 Hackintosh running vanilla kernel 1.25 GHz G4 macmini 20" iMac Core2Duo 2GHz Dual 1.8GHz G5 |
Help Strange Graphic Issue w/I7 Build and Pro Tools 8 | JustinTapp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-17-2009 05:25 PM |
New Quad Build, Need Opinions | Safjuan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 12-24-2008 01:30 AM |
Quad Machine Build Help! | ~Christian~ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-23-2008 08:38 AM |
Quad core processor - does it work with pro-tools?OS matter? | SamuelAdams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-15-2008 10:52 PM |
Going to build a Quad Core.... | s0nguy | Pro Tools TDM Systems (Win) | 11 | 01-29-2007 07:32 PM |
